390 swap
Old Apr 19, 2009 | 07:59 PM
steveo420's Avatar
steveo420
390 swap
I have a 82 bronco that had a 351m and i want to install a 390. Do i use i6 motor mount towers (like the 73-79s)
Old Apr 19, 2009 | 08:07 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
The problem you will run into is Ford never put the FE block in a 1980 up frame. Don't know what mounts will work, but maybe a 360-390 4WD pan for a 73-76 might work for starters, maybe 460 frame mounts, possibly someone on here has done that. 390 is one heck of a strong engine, I had a camper special in a 77 F150, it would really haul and got 16-17 highway with 3.25 gears in a 9".
Old Apr 19, 2009 | 09:53 PM
Franklin2's Avatar
Franklin2
Installing a 390 is a full custom job. Some people have done it, but they all do it differently, because it will not fit without some fabrication. A lot of work and thought to install a motor when there are others that just drop in.
