Sponsored by: Real Truck
Cruise Control test help
Old Apr 19, 2009 | 07:09 PM
wcurtis's Avatar
wcurtis
Mike Harrington posted this test a while back (Thanks Mike) see Below
My question is what & where is the speed control servo?? The only flash was when I started the test, the way I read this is the speed control servo defective
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<TABLE class=MsoNormalTable style="mso-cellspacing: 1.5pt" cellPadding=0 border=0><TBODY><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes; mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: #f0f0f0; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #f0f0f0; WIDTH: 100%; PADDING-TOP: 0.75pt; BORDER-BOTTOM: #f0f0f0; BACKGROUND-COLOR: transparent" vAlign=top width="100%">Try this test:
Diagnosing/Resetting the Cruise-Control operations:
1. fully engage parking brake. Make sure brake peddle is released.
2. Begin static portion of self test by pressing and holding speed control off switch.
3. Turn ignition switch from off to run. The cruise indicator on the instrument cluster will flash once to indicate the speed control module has entered diagnostic mode.
If the cruise indicator does not flash repeat steps 1-3. If the cruise indicator still does not flash, diagnose the cruise indicator.
4. Release the off switch
5. The cruise indicator will flash when each switch is pressed. While performing self test. Press each switch in the order described while observing cruise indicator for a flash. Note any switch activations that does not cause a flash.
Within five seconds of turning the ignition switch to RUN:
Press the on switch.
Press the resume switch.
Press the coast switch.
Press the set/accel switch.
6. NOTE: the on switch must be pressed within five seconds after entering the diagnostics mode or the speed control module will return to normal operating state and self-test must be repeated.
Flash Code Function Tested Possible Cause
0 Speed Control Servo Speed Control Servo Defective
1 Complete System
2 Stop Light Switch Circuitry Stop Light Switch Circuitry
3 Brake Deactivation Circuitry Brake pressure control
valve defective circuitry
4 Vehicle speed sensor Vehicle Speed Sensor Out of
range
5 Speed Control Servo Speed Control servo defective<o></o>
</TD></TR></TBODY></TABLE>
__________________
2003 Ford F-250 S/D <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comffice:smarttags" /><st1lace w:st="on"><st1:City w:st="on">XLT</st1:City> <st1:State w:st="on">SC</st1:State></st1lace>, 4X4, 6.8 V10 Triton, 4.30 axles w/Gear Vendors overdrive. Firestone 265/75R16 Transforce HT. Pullrite 16k Super 5th hitch/2006 Cardinal 30LE WB
Mike Harrington <o></o>
Old Apr 20, 2009 | 06:39 PM
wcurtis's Avatar
wcurtis
bump ! Please
Old Apr 20, 2009 | 09:00 PM
F350-6's Avatar
F350-6
So you're not getting a flash when any of the other buttons are pressed during the test, and it does the same thing no matter how many times you run the test?
trippn4re
23
Jun 2, 2014 04:16 PM
TexasEX2K
Jul 5, 2012 10:46 PM
lorenambrose
3.0L V6
Jun 26, 2010 07:53 AM
dpellicone
Mar 21, 2010 08:31 PM
