Well today climing a pretty good grade, unloaded, I saw the highest temps yet. I hit about 1100-1200*. Should this concern me, I have never been above 1000* but never climed this type of grade. I had the cruise on and the truck lost speed and the tranny wasnt shifting down. I gave it a little throttle and it kicked down and the turbo spooled up and the temps settled down to around 800*
The truck is a bear and probably would have lugged its way up the hill without down shifting. So you all know I run Innovatives Street Tune most of the time unless I tow heavy, when I say heavy I mean a car or something, I dont take the tune out to haul some brush to the dump.
I just want to make sure this is ok I am planning a trip to PA, and I will be going from Reading up to Penn State and there are some pretty steep grades out that way.
I am wondering should I put it in Tow/Haul when beggining the climb to keep the revs. up or just let the tranny do its thing. My concern is the loss of speed.
I have done 7% grades for 6 to 7 miles going to the Sierras in August when the temps in Bishop are over 100 and when I get to the 9,000 foot level it is still in the low 80's. This is with 12 to 13k of 5er behind me. The temps will climb pretty good if I don't take over. The tow command will take it out of overdrive but the engine will continue to drive the load in 4th. Once I back off a little and manually pull it down to 3rd and stick around 45 to 50 mph the temps drop drastically in a matter of a minute or 2. The engine is a brute and doesn't know when to quite so you have to change the playing field by letting the gearing do the work and not the engine.
If you are towing....esp in hilly are, keep it in tow/haul mode.... that's why it's there. This truck/engine/tranny combo. is a brute! It'll take most anything you throw at it - except an OVERBOOST situation - then you'll stretch the head bolts and disaster....
keep it in T/H if you have a load behind you..often, i'll coax the transmission to downshift before I get to the bottom of the grade..this keeps my speed up..
1200* is nothing to worry about when towing..i've pulled steady for 10 miles at 1250* in 110* heat..
during long hard pulls, as the motor starts to get heat soaked, you may notice a slight reduction in power..once various fluid temps reach a certain temperature, the PCM will pull some fuel back to protect the engine..
It never overboosts, and since I am driving it more now its been good as far s the veins not sticking. I figured all was ok, this iss the first steep grade with this truck in a while and I kinda forgot that I had to tell it to down shift. This truck pulls so good it was in fifth and no boost still chuging along up the hill.
My 04 with late 03 engine had a hard time pulling the grade I will be pulling in PA on my way up to college even when I helped it. I never pursued it cause I didnt have the truck long enough, but I am glad this is nothing to worry about.
I'm not trying to compete with advice but I prefer to use the gearing that is there for a reason than wait for the pcm to start defueling.
