manual hub conversion
Old Apr 19, 2009 | 06:00 PM
04redstroker's Avatar
04redstroker
Will the warn hubs for 99-04 work on my truck even though i have auto hubs?
Old Apr 19, 2009 | 06:18 PM
dchamberlain's Avatar
dchamberlain
Yes. The Warn and Warn Premium hubs for 99-04 are designed to replace the auto hubs.
Old Apr 19, 2009 | 06:19 PM
Sarge261's Avatar
Sarge261
Yes I believe they will and I am almost sure that they are a direct swap too. On some years you need a spindle nut kit but I dont think you need it in 04.
Sarge
Old Apr 19, 2009 | 07:02 PM
04redstroker
how does it cap the vacumm lines?
Old Apr 19, 2009 | 07:04 PM
Sarge261's Avatar
Sarge261
I beleive that you have to do that. You can disconnect them at the hub and use a small bot with a clamp and zip tie them up to the abs sensor wire or do it at the fender where the control module is. Either way is good.
Sarge
