Sponsored by: Real Truck
Adjusting auto tranny selector
Old Apr 19, 2009 | 08:18 AM
TedZ's Avatar
TedZ
Hi,
Searched a lot but did not find info. 1999 F350 supercab diesel dually. Won't start in park any longer, will in neutral if you do the wiggle.
Is there an in-cab adjustment? Tranny selector with the wiring harness is on the passenger side of the transmission and does not look adjustable but may be.
Thanks.
Ted
Old Apr 19, 2009 | 08:59 AM
riggz's Avatar
riggz
Isn't there a switch in the steering column that allows the truck to be started only in P or N?
Old Apr 19, 2009 | 10:03 AM
TedZ's Avatar
TedZ
There could be. I'll check it out.
Thanks.
Ted
Old Apr 19, 2009 | 11:03 AM
Furian's Avatar
Furian
You Keep What You Kill
Old Apr 19, 2009 | 11:41 AM
BobbyDiesel71's Avatar
BobbyDiesel71
Originally Posted by TedZ
Hi,
Thanks.
Ted
You probably need a NEW PRNDL switch
check the connection at the transmission. Relatively inexpensive and easy to replace.
