Sponsored by: Real Truck
rear bearings
Old Apr 18, 2009 | 03:43 PM
monticeno's Avatar
monticeno
rear bearings
Ive looked in two different manuals. One says to repack the wheel bearings with grease, the other said not to, that they are lubed from the diff oil.When I removed the bearings they were not packed with grease,only had gear lube on them. Thoughts?
Old Apr 18, 2009 | 03:55 PM
ruschejj's Avatar
ruschejj
What truck? What's the axle code? How many miles? How does the diff. oil look/smell?
Old Apr 18, 2009 | 03:57 PM
Monster-4's Avatar
Monster-4
I would repack them. It will help until they get full lubed by the gear oil. Here is a good link that discusses this.
https://www.ford-trucks.com/forums/7...ake-shoes.html
Edit: seems in the link I gave most are not in favor of repacking the bearings but pre-lubing them with gear oil. Probably a better idea now that I think about it.
Old Apr 18, 2009 | 10:33 PM
monticeno's Avatar
monticeno
2001 f250 with the 10.5. 160k oil smells and looks good.
Old Apr 19, 2009 | 06:26 AM
ruschejj's Avatar
ruschejj
I agree with Monster-4. Soak them in gear oil and install. If you don't mind, check them out after you get a few 1,000 miles on them.
Old Apr 19, 2009 | 07:08 AM
monticeno's Avatar
monticeno
Thanks for the input. Im putting it back together today.
Old Apr 19, 2009 | 11:34 AM
Scottay's Avatar
Scottay
The spec for my 2001 F350 SRW states to pack the bearings with grease (Premium Long-Life Grease XG-I-C or equivalent meeting Ford specification ESA-MlC75-B) and to put an of ounces of axle lube in hub cavity. Also coat the spindle with axle grease as well prior to re-installing the hub.
