Sponsored by: Real Truck
Normal then spongy breaks
Old Apr 18, 2009 | 02:14 PM
cbrgary's Avatar
cbrgary
Normal then spongy brakes
I have a 1997 Ford F250 Diesel. Several weeks ago the brakes got real hard to push after the initial stopping. What I mean by this is when I approach a light to stop, I push the brake pedal and all feels fine and the truck will stop good. If I let the pedal up to coast (ie: when in traffic) then try to push the brake pedal again, it's very hard to push almost like there are no power brakes (ie: like the old manual non power brake trucks).
At this point I replaced the master cylinder and bleed the brakes but no difference.
Anyone got any suggestions?
Old Apr 18, 2009 | 09:05 PM
F350-6's Avatar
F350-6
You've got a hydroboost, right? If so, try flushing the power steering fluid (uses ATF)
Old Apr 19, 2009 | 01:40 PM
cbrgary's Avatar
cbrgary
Ok, just for my knowledge, how does that tie in with the brakes????????
Old Apr 19, 2009 | 03:18 PM
dougc's Avatar
dougc
From what my mechanic tells me, the brakes and the power steering use the same reservoir. That might over simplify things, but, there you go.
Old Apr 19, 2009 | 04:32 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
WRONG!!! Your system prob has air in the ANTI-LOCK system. I don't know where the instructions are, but I'd start up in the top of SUPER DUTY and look through the TECH Folder first: here ya go.... https://www.ford-trucks.com/forums/4...lder_____.html
Old Apr 19, 2009 | 04:47 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
On the diesels, the HydroBoost system uses power steering pressure for brake assist.
If the ABS system had air in it, it's usually like that all the time.
Old Apr 19, 2009 | 07:04 PM
dougc's Avatar
dougc
Like I said, I over simplified things.
Old Apr 19, 2009 | 08:25 PM
cbrgary's Avatar
cbrgary
Thanks everyone
Old Apr 19, 2009 | 08:43 PM
F350-6's Avatar
F350-6
So do some of the gassers. I've got a 94 450 that has hydroboost with a 460 engine.
Old Apr 19, 2009 | 10:07 PM
krewat's Avatar
krewat
Well, on the SUPERDUTY, anyway
And besides, ALL the diesels have it, but not all the gassers (pre-Superduty).
Fords412
Jan 19, 2019 08:30 PM
EffoneHunded
Mar 10, 2012 04:13 PM
CopenGrizz01
13
Feb 24, 2012 07:48 AM
jon1
Bronco II
Jun 25, 2008 01:59 PM
