I have a 1979 Ford F100. A friend of mine has a 1976 Ford F150 I need a few parts out of it and i need to know if they will fit my truck or not. He told me i have to get them out of his truck tomorrow so i need yalls help ASAP! I need the steering column, alternator, and air filter. will these parts fit my truck. Both trucks are manuals. PLEASE HELP!
I am going to be removing these parts tomorrow and i really really need to know if they will fit or not because its gonna be some hard labor and i really dont want it to be for nothing.
if its a tilt column it i dont think it will work unless you swap wiring harnesses,,could be wrong though,,and im assuming you meant 390 instead of a 398?
these parts are fairly easy to remove,take them and worry if they fit later. the steering column i bet fits,alternator should fit, air filter may or may not.i think your going to be safe with these parts fitting. if there free or cheap go get them.
I agree, take the parts if time is the problem, most old ford alts mount the same. I'm not sure about the steering column, and I would use an aftermarket air filter.
alright thanks for yalls replies. i will be going over there in about an hour when he gets home and yeah he's letting me take anyparts i need for free. I was just hoping that the steering column would fit. Is there anyway i could make it fit? or would it be to different? my truck really needs a steering column but i have NO money to get one right now and i need my truck mobile again.
well first of all it was made for an automatic. second it moves around, when you grab the steering wheel to drive it moves everywhere which makes it impossible to steer.
^ ^ ^ 1973/77 IS THE SAME / 1978/79 IS DIFFERENT! ^ ^ ^
Originally Posted by nar&sfg
i found something on the internet that steering columns from a 67-79 ford f-series will fit all f-series trucks from 67-79. is this wrong?
(sigh) What did I type in post #9?
Anything will fit if you make the necessary modifications.
You cannot remove a steering column from a 1967/72 and install it in a 1973/77 and expect it will bolt right up, and you cannot take a steering column from a 1973/77 and install it in a 1978/79 for the same reason.
And...if a 1967/69 F100/250 has P/S, the column will NOT work in a 1970/72.
I was a Ford partsman for 35 years, I have the parts catalogs. I'm typing facts, not heresay, rumor...or I read it somewhere.
Look at the bottom of the steering column under the hood at the steering coupler aka rag joint that connects the column to the steering gearbox.
If the rubber has torn, or the bolts have sheared off...there's the cause of your wandering steering.
You can buy a rag joint repair kit at a parts store for about 10 bucks.
btw: The rag joint from a 1973/77 WILL NOT FIT a 1978/79.
