On a 86 F250 where would the trans cooler be located? There was a radiator swap done on the vehicle before I purchased it, I have no idea if there was a trans cooler there before, but I do not see one there now. There are a few lines located in the vicinity of the bottom of the radiator. They appear to be 1/2"-9/16 in exterior diameter. I have not had a chance to trace them yet. Am I looking in the right place?
Will
Alsip, IL
86 F250 4x4 351W
-Plow Truck, Western 8'6"
97 Explorer XLT 4x4 4.0 SOHC
-Lifted 2.5"
99 Jeep Sahara 4x4 4.0 I-6
-Stock for now
I am pretty sure it should be on the driver's side of the radiator. There should be a line near the top and one near the bottom. The trans oil cooler is located inside the radiator.:+
Most rads for an automatic tranny have a special tank on the bottom of it underneath the vanes of the rad.That's all.
If you pull a trailer it would be good idea to run an accessory cooler in front to the rad that is hooked up in series with the rad tank cooler.
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG [font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"[/font]
