overheating fun
Old Apr 17, 2009 | 05:54 PM
trugertha's Avatar
trugertha
overheating fun
was out on the trail heat went above the red looked for leaks no leaks so i got to the main trail and decided to check my water and there was no pressure i could just take the cap right off? any ideas thanx
Old Apr 17, 2009 | 06:08 PM
starmilt's Avatar
starmilt
Was it full of coolant.
Old Apr 17, 2009 | 06:19 PM
trugertha's Avatar
trugertha
haha you know it buddy .. thats y in scared theres no pressure can't afford to upgrade to a newer truck yet
Old Apr 17, 2009 | 06:24 PM
starmilt's Avatar
starmilt
If it was full and no pressure it wasn't hot then. Maybe your guage is acting up.
Old Apr 17, 2009 | 06:27 PM
trugertha's Avatar
trugertha
shouldn't there still be pressure on it or would the gauge not allow the thermo to open
Old Apr 17, 2009 | 06:37 PM
starmilt's Avatar
starmilt
The guage has nothing to do with the thermostat.
If the thermostat doesn't open it will pressurize from the heat.
If the water does not circulate it will be pressurized from the bottom hose.
It is not unusuall for a diesel not to have much or any pressure.
Old Apr 17, 2009 | 08:07 PM
trugertha's Avatar
trugertha
ooo see i did not know that this is my first diesel and allthough i've had it for 3 years its just starting to have a few problems maybe it didn't like the 130,000kms i put on it in those years haha..but neways can the thermostat get stuck open??
Old Apr 17, 2009 | 08:37 PM
starmilt's Avatar
starmilt
Yes it can stick open I had to change mine for that reason this winter.
Old Apr 17, 2009 | 09:52 PM
trugertha's Avatar
trugertha
k so found sending unit on head behind ps pump? pull off heat gauge goes back to normal but still works? wtf is going on here haha does it have something to do with the red wire hooked to the sending unit on the intake ??? im so lost
Old Apr 17, 2009 | 11:12 PM
farmert's Avatar
farmert
There are 2 sending units, one for the gauge and one for the light. When the one for the light reaches a certain temp. it will peg the temp gauge to the hot side. It sounds as if the sender for the light has gone bad.
Old Apr 18, 2009 | 02:15 PM
trugertha's Avatar
trugertha
farmert you have made it all clear for me ill goto ford and pick one up thanx bud.
crivaro
2004 - 2008 F150
Jul 17, 2011 05:23 PM
fuzzy1626
1983 - 2012 Ranger & B-Series
Jan 10, 2009 02:41 PM
WiseMagic
Apr 24, 2008 09:38 AM
berry1234
15
Dec 7, 2007 08:00 PM
