starter question.
Old Feb 11, 2009 | 02:33 PM
tjc transport's Avatar
tjc transport
i ain't rite
starter question.
ok, so the young one put the new starter in the 88 this morning, and it starts again like it did 21 years ago.
but i have a question. did not the 88 come with a direct drive starter??
a gear reduction came out of it, and the truck has never been inside a mechanics shop since the day i got it with 4 miles on it, and i never put a starter on it.
Old Feb 11, 2009 | 02:47 PM
Lazy K's Avatar
Lazy K
My `87 6.9 has a gear reduction, if that`s any help.
Old Feb 11, 2009 | 02:52 PM
kenpobuck's Avatar
kenpobuck
Autozone told me they were the same from 83-94 for the IDI motors.
Old Feb 11, 2009 | 04:02 PM
tjc transport
i ain't rite
i know they are the same for 83 to 94, but i thought the stock started was a direct drive, and the gear reduction was an aftermarket starter up to the introduction of the powerstroke, when they switched over to a stock gear reduction unit.
Old Feb 11, 2009 | 05:03 PM
82F100SWB's Avatar
82F100SWB
As far as I know, only the 83 and 84's came with the direct drive starter, I know my buddy's 85(engine is in an 88 crew now) and my 86 both had gear reduction starters, the one on my 86 was for sure factory.
Old Feb 11, 2009 | 05:13 PM
351M's Avatar
351M
all 7.3s and some 6.9s had the Mitsu gear reduction starters. I have a Part # at home for a Nippondenso starter that interchanges with the 7.3 ones. It is for a Case Loader. So if you like i can post it up. I have not looked into it very far yet but that is the way I am planning to go as they are supposed to last alot longer then the mitsu ones and i believe are a lot more powerful.
Old Feb 11, 2009 | 05:59 PM
tjc transport
i ain't rite
ahhh ok. i was not aware it was only the 83 and 84 that got the direct drive.
21 years out of a starter ain't bad i guess. it probably would have lasted longer, but i have to reseal the engine. every gasket on the dang thing leaks, and the passenger side valve cover is the worst. oil actually poured out of the starter.
it leaks just about a quart every 100 miles.
it is going into the shop next week for a complete recondition of the frame, a new cab, dump body, and the dual wheel setup is going back on it as i have more of a need for it as a dump truck than i do as a pickup, and while it is apart i am going to re-gasket it.
Old Feb 11, 2009 | 10:04 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Some had Nippondenso gear reduction starters,
and some had Delco direct drive starters.
The Mitsubishi gear reduction was later 7.3 engines and Power Strokes.
Old Feb 11, 2009 | 11:00 PM
1dieselman's Avatar
1dieselman
Both 85s I used to have also had the direct drive, until I got fed up and changed them to Mitsubishi starters
Old Feb 12, 2009 | 09:17 AM
JOEOIL's Avatar
JOEOIL
just took the misubisi out,put in the one for the case loader in
Old Feb 12, 2009 | 09:19 AM
JOEOIL's Avatar
JOEOIL
tom were in larance harbor ,i live in hazlet,
JOEOIL's Avatar
JOEOIL
don't have enogh post to pm
Old Feb 12, 2009 | 09:21 AM
JOEOIL's Avatar
JOEOIL
did you take the truck to the shop to put dulley rear i have an 87 ,may be we could trade save$
Old Feb 12, 2009 | 09:23 AM
JOEOIL's Avatar
JOEOIL
the 87 is a dulley
sorry for all the short post trying to be abil to pm
Old Feb 12, 2009 | 10:52 AM
tjc transport
i ain't rite
i never took the dually rear out of it Joe, i just put SRW tires on the rear, and took the adapters off the front.
i wish i saved the front adapters though, i an having a hard time fonding a set.
i am on the waterfront in the harbor, near the ball courts.
