Stump puller motor
Old Apr 19, 2009 | 09:57 AM
HIGHBOYSCOTT's Avatar
HIGHBOYSCOTT
Ok, back to the 390.... From what I'm gathering from Numberdummy's post, I can just keep my flywheel, that is unless it's thrashed, but I doubt that it is. I'm going to go with a 650 carb and probably just call comp cams and ask them what the best cam to run for my needs will be. Any suggestions on ignitions? Will the stock ignition system give me enough spark? A friend of my ran pertronix (spelling?) on his f100 that had a 360 in it. He said that really woke the engine up and made it run better. You guys have any experience with that set up? Again, thank all of you for the great input.
Old May 19, 2009 | 03:44 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
Ford Distributors
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/...d_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old May 23, 2009 | 07:25 AM
HIGHBOYSCOTT
Well Mr. FTE sponsor guy....I took your advice and bought the D.U.I setup and the wires to go with it. I did some research and really liked what I saw. Tell your boss to give you a raise.
Old Jun 4, 2009 | 02:03 PM
PerfDistIgnition
FTE Sponsor
Thank-you! Hope you are very pleased.
__________________
FTE Sponsor
parkland
General Diesel Discussion
140
Sep 24, 2016 12:47 PM
Martin Torres
Sep 2, 2016 11:56 PM
74f100sc
15
Feb 23, 2016 11:26 PM
SillyValleyF250
Jul 23, 2008 08:04 PM
rforsythe
Aug 31, 2003 01:37 PM
