Modular V10 (6.8l)
Checking Spark Plug Torque
Old Apr 16, 2009 | 08:43 PM
WilleyB's Avatar
WilleyB
Question Checking Spark Plug Torque
Well it's getting close to time to take the rig on the highways again. Although the plugs were changed 2007 the rig wasn't used for any trips last year. A bit shy after a plug blowout I guess.
Anyway before setting out on a 6000 mile trip I'd like to check the torque of the plugs just to be on the safe side. I have all the tools required and will pick up stuff for the boots.
Ok the torque is 14lb ft or 168in lb I have torque wrenches in both measurements.
Getting to the question, kind of stupid, but I want to do it right the first time. Do I just set the wrench to the correct torque and try it on the plug until it clicks or am I supposed to loosen the plug first then set it?
Willis
Old Apr 16, 2009 | 09:20 PM
Fordfanatic4life's Avatar
Fordfanatic4life
no, just check it and make sure it clicks...
no need to remove/loosen the plugs first...
i'd only remove a plug if u suspect theres a problem, as in to tight or loose...
Old Apr 16, 2009 | 09:40 PM
WilleyB's Avatar
WilleyB
Ok thanks I just wanted conformation on what to do. Darned if I want to go through that experience again.
Willis
ForeverFixing
Mar 28, 2017 05:35 PM
Tugly
15
May 21, 2016 02:48 PM
los341
6.7L Power Stroke Diesel
24
Jun 15, 2014 10:20 AM
EXv10
Jul 6, 2012 10:07 PM
tombob
Garage & Workshop
Oct 2, 2006 07:17 PM
