found 5 speed in a 78 F600.. need help w/ ID
Old Nov 30, 2002 | 10:55 PM
dablack's Avatar
dablack
Ok, I've got a 74 460 in my 71 SWB. I would really like to take out my old leaky C6 and put in the 5 speed I found in a 78 F600. Tomorrow I'm going to make sure it is behind a 460, but what about the rest. I will probably need to get some parts for this thing. How can I tell if it has OD? This is a 4x4 truck I'm pulling it from and it also has a high/low shifter in the cab as well. Does it work w/ the 4x4 or does it go w/ the tranny or what? I will post what ever numbers I find on the tranny but would really like some info on what to look for.
Thanks
Austin
Old Nov 30, 2002 | 11:39 PM
deere81's Avatar
deere81
The 5 speed in a F600 is likely to be a Clark or New Process. I really doubt that it is an overdrive transmission. The truck might have a 429 in it.
'90 F-150 351 AOD "The General"
'78 F-250 460 C-6 "Old Green"
'93 Mustang 5.0 AOD
'88 Jeep Cherokee 4.0
Old Dec 4, 2002 | 09:28 PM
acogoff's Avatar
acogoff
My f600 farm truck has a 2 speed eaton rear end W/ button on shifter. A 4wheel F600 must have been an electric co. truck or similar use. Also have a c700 farm truck with clark 5speed And 360 engine.
Old Dec 4, 2002 | 10:16 PM
elliott's Avatar
elliott
According to a truck Motor Manual, if it is stock, the engines offered in 78 for a F600 are; 300 or 330: Also a chance it might be a late 361 or 391 or an early 370 (first shows up in 79). Transmission could be; Fuller, Spicer, New Process or Clark or a HD 4sp. If you take the Vin # & the trans letter to your Ford parts man, he should be able to ID it for you. Hope this helps, Elliott
Old Dec 4, 2002 | 10:25 PM
elliott's Avatar
elliott
Large Truck
29
Apr 3, 2016 06:05 PM
jbehuniak
Mar 4, 2016 11:10 AM
Jared Trout
Jan 22, 2014 03:11 AM
mse871859949
Jun 13, 2013 06:11 PM
mando jake
Oct 20, 2007 09:36 PM
