Excursion Problems....Please Help
Old Apr 15, 2009 | 09:05 PM
SystematicX's Avatar
SystematicX
Hello Everyone,
I'm sure these are basic mechanical questions, but I want to make sure what I think is the problem is the problem.
Problem #1:
Really nasty jerk from 1st to 2nd gear.
Problem #2:
I know there is a leakage near my driver side rear, it's starting to smoke up when a lot of heat is accrued from driving a hot day or just driving in general.
Your inputs would be greatly appreciated. Please help me take care of my baby....
Old Apr 16, 2009 | 10:15 AM
howler4x4's Avatar
howler4x4
Originally Posted by SystematicX
Problem #2:
Sounds like the rear axle seal.
I'ts best to replace the seals on both sides. Check the condition of the axle bearings too.
Don't continue to drive without checking the rear axle fluid level.
Old Apr 16, 2009 | 10:39 AM
bubbasz1's Avatar
bubbasz1
More information required, what year, motor, and how far back is the leak.
Old Apr 16, 2009 | 01:53 PM
Monsta's Avatar
Monsta
Sit. Stay.
+1 on what bubbasz1 said.
Have you check your tranny fluid level?
Old Apr 16, 2009 | 09:26 PM
SystematicX
2001 Limited, V-10, 4 x 4.
I don't know how far back the leak is. When I had a chance there was residue on my inner rim, slightly greasy. Checked the other rear wheel and no similar residue was found. If you need more info please let me know and thank you for all your help, much appreciated.
Old Apr 16, 2009 | 09:27 PM
SystematicX
I haven't checked the tranny fluid level, but I will and update when available.
Old Apr 16, 2009 | 10:25 PM
howler4x4's Avatar
howler4x4
Only 2 fluids should be able to leak onto a rear wheel rim; brake fluid or 75W-140 from the axle.
They are very different, easy to tell one from the other. If you are losing enough of either to see smoke you need to fix it ASAP.
Old Apr 16, 2009 | 11:11 PM
SystematicX
Thank you for the information. I will notify by vehicle technician as soon as possible.
