Cam phasers
Old Apr 15, 2009 | 01:56 PM
RJM4u's Avatar
RJM4u
Cam phasers
About 2 months ago my 2004 F-150 truck started having tappet noise on idle. I thought nothing of it. Two weeks ago, I changed the oil and filter at 46000 miles and the emission light came on. I paid a Ford dealer $145.00 to troubleshoot it and they came up with:"You need a new alternator for $565". I then took it to a very reliable and honest mechanic and after 12 hours, told me the driver side cam phaser was not operating and the oil galleries were gunked up. To replace BOTH phasers, flush the oil system, replace the spark plugs--$2300.00 including $120 troubleshooting. I get the truck, guaranteed 1yr., in 2 days.
Old Apr 15, 2009 | 05:47 PM
ggwash21's Avatar
ggwash21
FORD ESP...... I just had the same thing done. cost me $100 on a 2004 FX4 5.4l 24v with 68,000
Old Apr 16, 2009 | 03:31 PM
PME2.5's Avatar
PME2.5
I also just had the same thing done after an oil change and filter, 55,000 miles but under warranty though, cost 100.00, No Warranty??
Old Apr 16, 2009 | 03:37 PM
Sethw3's Avatar
Sethw3
Crap mine has started that tapping sound.
Old Apr 16, 2009 | 03:44 PM
PME2.5's Avatar
PME2.5
And what exactly do cam phasers do??
Old Apr 16, 2009 | 07:42 PM
ggwash21's Avatar
ggwash21
I have warranty but its extended ford ESP which i have a deductible which is better then paying $2300
Old Apr 16, 2009 | 08:45 PM
stanger_missle's Avatar
stanger_missle
Here, read this Wikipedia article: http://en.wikipedia.org/wiki/Variable_Cam_Timing_(Ford)
I know its kinda technical, but basically the Powertrain Control Module opens a solenoid that lets oil flow into the cam phasers, which are located on the end of the camshafts (like cam gears). The oil limits how much the cams are retarded or advanced. Its an effective way to change cam timing to reduce emmissions, increase gas mileage and engine power.
Old Apr 18, 2009 | 06:44 AM
markstanfield's Avatar
markstanfield
Cam phasers
I've read a ton of articles regarding the phasers. What I can't seem to find is if there have been any engine failures (blown) due to phasers? Do the noisy phasers "fail" at some point?
My '04 5.4 with 134,000 has had the noise for over 100,000 miles. I've used Mobil 1 5W-20 from day one...
Old Apr 18, 2009 | 08:53 AM
BirdmanStyll's Avatar
BirdmanStyll
yeah my 5.4 has been doing it since 100,000km im at 114,000km and i only use mobil1 5w 20 apparently its normal?
Old Apr 18, 2009 | 09:41 AM
ggwash21's Avatar
ggwash21
I use nothing but motorcraft oil 5w20 but i have not seen anyone blow their motor due to cam phasers but i lost a lot of gas mileage. When it started happening i was getting 19mpg and when it got the worst i was getting 12mpg and about 3 tanks after that im up to about 17mpg so far
Jon11B
2009 - 2014 F150
Jul 11, 2014 12:35 PM
jrroth
2004 - 2008 F150
Sep 17, 2013 05:44 PM
Mike(GA)
2004 - 2008 F150
May 28, 2012 10:24 AM
VINZB
Modular V8 (4.6L, 5.4L)
May 26, 2011 10:08 AM
thomas_e102
Sep 5, 2010 11:05 AM
