oil pump?
Old Apr 14, 2009 | 05:17 PM
z1121jack's Avatar
z1121jack
oil pump?
I am rebuilding a 351w and in the process installing a new oil pump. I purchased a book on small block Ford engines, which states "after market shafts require pressing a shaft collar"
What I NEED TO KNOW is were do I get a "shaft collar"? Don't think one came with the oil pump.
Old Apr 14, 2009 | 08:49 PM
Conanski's Avatar
Conanski
The collar is a little sheet metal thing that slides on over the shaft to prevent it from getting accidentally pulled out when the distributor is removed after the engine is assembled. If you have the original oil pump shaft the collar should still be on it, make sure the collar is tight to the block after the pump is installed.
Old Apr 15, 2009 | 06:17 AM
z1121jack's Avatar
z1121jack
thanks I'll check
