pulling rear drums?
Old Apr 14, 2009 | 01:12 PM
bmwfreak's Avatar
bmwfreak
pulling rear drums?
newbie question; have not located a manual as yet
how does one pull the rear drums? special tools?
want to check the wheel cylinders and replace e-brake cables
thanks
Old Apr 14, 2009 | 01:21 PM
bmwfreak's Avatar
bmwfreak
nevermind
loosened the adjuster from behind and tapped the drum off
good thing for little brothers who are mechanics (even if a 2 wheel mechanic!)
Old Apr 14, 2009 | 01:27 PM
Ed's 64's Avatar
Ed's 64
thanks
chock block both front wheels release emergancy brake jack truck up in back remove tire
now grab a hammer not real hard but not sissy type give it even blows with the hammer. hit the drum flat with hammer around the center out side of lugs and dont hit the lugs. some come off easy but if its been yrs it'll take few mins hittn with a hammer. i use a small 3lb sludge hammer a heavy rubber mallot would be better just be patient and use even flat blows with the hammer once it loosens it'll remove very easy. just the nature of this beast with back drums . on my 1964 tis what i had to do and still have to do every time i change rear brake shoes. i had to replace both front wheel cylinders on mine i used 1969 3/4 ton a friend had for parts. his left front cylinder was my right front per my local brake warehouse nevada brake
Old Apr 14, 2009 | 01:28 PM
Ed's 64's Avatar
Ed's 64
kool i'll remember that lol been doing it cave man style since little kid
Old Apr 14, 2009 | 02:45 PM
camperspecial65's Avatar
camperspecial65
you will have a big problem if you dont remove those flat head screws in the area between the axle studs as they hold the drum to the axle...
- cs65
