Another 7.3 not starting...
Old Apr 14, 2009 | 10:22 AM
ggirten's Avatar
ggirten
Originally Posted by miller_feed
I'm not sure 5 gallons of diesel is enough. Did you open the fuel bowl drain, turn the key to the on position to look for a good flow of fuel out the hose under the engine?
Not sure about the flow, but we did empty the bowl and verified it refilled.
Old Apr 14, 2009 | 10:23 AM
ggirten's Avatar
ggirten
Originally Posted by just another truck
There is one other sensor ( I think ) that will do this to you.. IF you unplug it, you will be able to run, but not drive.. I want to say ICP?? Hopefully someone else will chime in with the right answer..
I had experience with that one on my son's truck, but no luck on this one.
Old Apr 14, 2009 | 10:27 AM
ggirten's Avatar
ggirten
Originally Posted by F350-6
Engine oil full? Make sure you didn't damage an o-ring and got the tin nut back on right when you swapped the IPR. Truck's not going to start if you're only seeing 50 psi of high pressure oil. Does IPR duty cycle go up to 65% while cranking? Unplugging the ICP sensor won't hurt and is worth a try.
Oil was changed even though it only had 2600 on previous oil. I haven't checked the duty cycle on the IPR. We pulled the IPR from my truck which is good, but no luck. We have unplugged the ICP. We are quickly running out of things to try. How likely is it that the HPOP is bad? I would think it was more likely a sensor or something else. When it quit, it just died and has never tried to restart. No symptoms before then.
Old Apr 14, 2009 | 11:00 AM
just another truck's Avatar
just another truck
Sorry Gregg.. I am just going to sit back and watch from here.. I am out of suggestions now..
Old Apr 14, 2009 | 11:02 AM
ggirten's Avatar
ggirten
Thanks for trying. I am at that point.
If it did run out of fuel, do you think it would be an air lock in the fuel rail?
Old Apr 14, 2009 | 11:28 AM
F350-6's Avatar
F350-6
The way to check is to disconnect one head from the HPOP (block off the line) and stick a pressure gauge in the head getting oil and monitor pressure while cranking, the do the same thing with the other head. That will make sure you don't have an issue in one of the rails dumping the pressure.
Is the reservoir staying full? You'll want to make sure this isn't a LP pump failure or a cracked pick up tube.
Old Apr 14, 2009 | 12:53 PM
ggirten's Avatar
ggirten
Thanks, we'll check the pressure tonight as well as the reservoir.
Old Apr 14, 2009 | 01:44 PM
ggirten's Avatar
ggirten
Do you know what size those fittings are?
Old Apr 14, 2009 | 03:43 PM
DemonRace6's Avatar
DemonRace6
Hi!
Subscribing and hoping you get it fixed
Old Apr 14, 2009 | 06:17 PM
Kwikkordead's Avatar
Kwikkordead
Subscribing here too.
Old Apr 14, 2009 | 06:23 PM
F350-6's Avatar
F350-6
Sorry, no. But with all the folks who have installed a crossover, you should be able to get an idea what size fitting you need for the gauge.
I'll bump this back to the top
Old Apr 14, 2009 | 08:31 PM
4DTech's Avatar
4DTech
High pressure oil leak.... Under the valve cover high pressure line going to the oil rail bolted to the top of the injectors... Check the Quick disconnect line.
Old Apr 14, 2009 | 11:01 PM
  #28
dledm's Avatar
dledm
It sounds like my '01 - everything looked OK, no codes, no start, no injection pressure. It turned out for me to be the UVC harness plugs came loose. An injector buzz test gave the codes. I reconnected, runs fine. Apparently if the computer doesn't see good connections to the injectors, it won't command for HPOP pressure.
Old Apr 15, 2009 | 07:46 AM
  #29
ggirten's Avatar
ggirten
Buzz test was OK. I think we still need to check the harness. While we are there, we will check all the oil connections.
He hooked a gauge to the HPOP last night and had 3000psi. So it looks to be good. Can't work on it tonight, so it will be Thursday before we check the harness.
Old Apr 15, 2009 | 08:19 AM
  #30
Kwikkordead
When it quit, did it stutter and taper down or just shut off?
