Bumper swap
Old Apr 14, 2009 | 05:21 AM
acfd527's Avatar
acfd527
Bumper swap
I have a 2005 screw with the rectangular fog lights in the front bumper. I like the round fog lights in the 06's better. Would everything match up? I figure the bumper will since they are the same truck, but wasn't sure about the lamps (Wiring).
Old Apr 14, 2009 | 11:05 AM
Greg B's Avatar
Greg B
I'm not sure, but I think they would match up if if the 05 uses the same bulb for the fog light as the 06. The harness plugs right into the bulb.
Greg B
Old Apr 14, 2009 | 12:10 PM
FTE Trigger's Avatar
FTE Trigger
I did a similar swap. Except I had a '05 XL bumper then put a '06 (w/fog openings) bumper on. All of my mounting points lined up nicely.
Though, it didn't last long against a sawed off concrete pylon I snagged at a friend's house. So i'm back to my '05 XL bumper.
Old Apr 14, 2009 | 12:51 PM
04XLTRUNNER's Avatar
04XLTRUNNER
i did the swap with my 05. put an 07 bumper on it. brackets are different and fog like brackets are different. also the bumper filler doesnt exactly line up like it supposed to. to do the swap theres more than just the bumper.
Old Apr 14, 2009 | 04:56 PM
FTE Trigger
I did have to fab my own light brackets... since I had no lights there to begin with.
Old Apr 14, 2009 | 09:54 PM
bigchief2472000's Avatar
bigchief2472000
if you decide to change em ill buy the one you have on there now.
Old Apr 15, 2009 | 05:49 AM
acfd527's Avatar
acfd527
Okay. I have been checking some of the salvage yards close to me, but no luck yet.
The main thing I was concerned with was the plugs for the lights. I never thought about any filler panels. Glad you brought that up 04XLTRUNNER. Did you have any issues with that Trigger? Since yours is the same swap (05-06)
Oh yeah, you have to watch those pylons, they will sneak up on you
Old Apr 15, 2009 | 08:09 AM
FTE Trigger
Try a body shop (even one that's attached to a Ford dealer) That's where I found the one I had. It just so happened a buddy of mine was working there and was able to secure it from a front clip that they had removed from another '06.
After thinking about it more, I did have to get a bit of help lining things up with my mounts. So I did use the bumper arms from the '06. I did not use my '05 mounts.
Old Apr 15, 2009 | 09:37 AM
acfd527's Avatar
acfd527
Okay, thanks a lot for the help. I hope to find one soon!
jonjovie
Jan 26, 2011 12:56 PM
bajaron
Dec 14, 2007 03:08 PM
lsu92
Aug 7, 2006 07:14 PM
fireftnford
1997 - 2003 F150
Feb 19, 2004 03:06 PM
