Grinding Noise
Old Apr 13, 2009 | 11:31 AM
Shovelhead 93's Avatar
Shovelhead 93
Grinding Noise
A guy I work with has an 04 F-150 4x4 scab he says it makes a grinding type noise when he is on the gas and it goes away if he lets up on the go pedal,he says it sounds a bit like it does when the 4x4 is engaging, any thoughts?
Old Apr 13, 2009 | 12:08 PM
xjcamaro89's Avatar
xjcamaro89
Vacuum leak somewhere in the IWE vacuum system for the 4WD. When your on the gas or under load the vacuum drops. Read this write up......
https://www.ford-trucks.com/forums/8...ml#post7322441
Old Apr 14, 2009 | 04:56 AM
Shovelhead 93
Thanks alot.
Old Apr 14, 2009 | 07:08 AM
xjcamaro89's Avatar
xjcamaro89
Let us know how it works out!
