newer engine
Old Apr 13, 2009 | 11:06 AM
unforsakenn's Avatar
unforsakenn
newer engine
Would i be able to put a newer engine block in my 78 f150. was hoping to put a newer engine block and components in my truck and just put all my intake and headers from this truck on the block
Old Apr 13, 2009 | 11:20 AM
73FOMO's Avatar
73FOMO
Shouldn't be a problem. I have a '92 block in my 73....bolted up, no problems. What exactly do you have in mind?
Old Apr 13, 2009 | 11:25 AM
jsutton's Avatar
jsutton
I have a short block from an 83 Grand Marquis with my 77 heads, intake, and all accessories bolted up to it. Shouldn't be an issue. It may depend on what engine you have though.
Old Apr 15, 2009 | 09:54 AM
unforsakenn
i have a 302 and i was wanting to put a 90's model engine in it cause there are tons of 98 ford f150s in a junk yard and the engines look brand new
Old Apr 15, 2009 | 10:05 AM
jsutton's Avatar
jsutton
98's didn't come with 302's I didn't think. I thought they were 4.6 by then? But I don't know for sure.
I don't think it would be a problem at all to put your intake on a newer 302 though. I did it. But make sure you get the harmonic balancer and flexplate or flywheel because the newer ones have a different balance than the old ones, so you won't be able to reuse yours.
Old Apr 15, 2009 | 10:35 AM
unforsakenn
ok thanks hopfully ill find a good decent one and start from there
Old Apr 15, 2009 | 10:55 AM
northerndave's Avatar
northerndave
somwhere around 93 the 302 went roller cam.
that'd be a good thing, I'm thinkin anyways.
Old Apr 15, 2009 | 11:03 AM
lasthighboy's Avatar
lasthighboy
i believe that the grinds on the fuel injection cams are much different than the older ones, and they dont run very good w a carb. you might have to change cams, but you can still run the roller lifters. i believe i read this on a page on edelbrocks website, and a guy i work with just built one this way.
