Trailer Brake Controller Problem
Old Apr 12, 2009 | 07:59 PM
kpriddy's Avatar
kpriddy
I am in need of help. I have a 1999 F-250 Superduty and cannot get my trailer brakes to work. The brake, turnsignals and lights all work. I have tested the main connection plug under the rear of the truck and when I hit the controller, I do not get a signal from the controller. I also cannot get a constant 12 V with the key in the "on" position. Any suggestions on where to start troubleshooting? I checked the large fuse under the hood and it isn't blown so I can't figure out why I can't get a signal at the plug. It has worked in the past and the controller is plugged in directly under the dash to the factory supplied plug. Thanks
Old Apr 12, 2009 | 09:32 PM
Franklin2's Avatar
Franklin2
Check the signals at the brake controller. You have a hot wire(I think that is red) a good ground(white?) and a blue which is the output to the rear brakes. There is another wire which I cannot remember the color, that is the brake signal going into the controller. It should have 12v when you hit the brake pedal.
old farm truck
All Things Towing
26
Sep 2, 2017 08:59 AM
pastorjeep
Sep 20, 2016 03:47 PM
RV_Tech
All Things Towing
34
Aug 29, 2015 04:29 PM
pdqford
Jun 9, 2012 03:13 PM
jeeplj8
Jul 1, 2011 06:11 PM
