Exhaust Manifold Repair?
I might just take the good manifold I have and trade it off. Its a newer exhaust manifold with the hot air tube in the manifold.
But I am not really messing with that car yet Im destpertly trying to finish the 63 ive been restoring since 2002.
Then again I might just go ahead and buy a new manifold, I mean after all you cant see the codes on the manifold anyways at least I cant.
Have you looked on ebay??? Of sourse it might be cheaper to put headers on it.
But you wouldnt happen to know of a place that sells reproduction bumper jack parts for 56 passengercars would you? I found other parts but still missing the lugwrench and maybe a jaw on the jack that fit up against the bumper if thats what they had, it just looks like its missing stuff.
C2SZ17032C .. Lug Wrench / Obsolete
DOUG STANLEY FORD in DeSoto TX has ONE: 972-223-8050.
DENNIS CARPENTER OBSOLETE PARTS in Concord NC has THREE: 704-786-8139.
The 1/2 ton trucks, Econolines, Bronco's ALL used this same lug wrench thru 1996.
Also used in most of the cars thru 1979, some of the cars thru 1996.
Ford did not sell the lift portion of the jack by itself.
B9A17080A .. Bumper Jack / Fits 1952/59 Passenger Cars / Obsolete
No Ford Dealer or obsolete parts vendor has any.
There are TWO different Y block right exhaust manifolds.
C2TZ9430D = 1954/64 F100/350: 239/256/272/292 / 1954/56 Passenger Cars: 239/272.
C2AZ9430A .. 1956/62 Passenger Cars: 292/312.
I'd search for either one...if I knew which one you needed.
What is the ID number off the old one?
I am not sure if the jack itself is complete. I have seen some GM ones that had a cradle that snapped inplace that fit againt the bumper.
The photos below are of all the jack pieces I have. I dont know if I am missing anything other than the lug wrench.
But its good to know Carpenter has them, I did a search for Bumper Jack and didnt turn anything up but I guess I should have tried Lug Wrench.
But its good to know Carpenter has them, The ones I listed are NOS originals.
I do not know if Carpenter has reproduced it. Besides reproduction parts, Carpenter has the second largest stock of obsolete Ford parts on the planet.
Ford used the SAME lug nut from 1932 thru 1996 on the half ton trucks, on all the Bronco's, E100/150 Econolines from 1961 thru at least 2000.
The same nut was used on cars from 1932...all the way thru 1979, then on others thru at least 1996.
Your jack is missing the goose necked lift that attaches to the jack, then to the bumper.
Read my previous post inre to the exhaust manifold.
I edit A LOT...so it's a good idea to read my posts again after the 1 hour FTE time limit for editing expires.
Thats what I thought. Theres a arm that comes out on the jack that I thought hooked to the bumper but it just didnt look right to me. Looked like something was missing.
Now this was what was all in the trunk when I first opened it before I found the main assembly of the bumper jack laying on the ground under cardboard. The green bracket at bottom right looks like a bumper jack cup or support but based off the color I think it goes to the screw jack that is also in the photo. I dont really know what that greenish blue is for or how you even work it. But if the jack is missing that gooseneck then I have to try and track that down. I know I probably wont use the jack but I like to have or keep all the pieces.
On the exhaust manifold I dont know the number thats on it but I would say its this one.
"C2AZ9430A .. 1956/62 Passenger Cars: 292/312"
And I will check that first post again in a few for any updates.
~Update~
I looked on ebay and came across 56 Tbird bumperjack it has everything mine has it doesnt have the lug wrench but it has the same tongue that I guess the other piece snaps into but god that guy is asking $325 buy it now on it.
~Update~
ulnpiper
15
12-21-2015 07:57 PM
pintoches
10-06-2008 08:19 AM
jaymontana
1947 and Older Ford Trucks
12-18-2007 03:03 PM
