Pony Carbs 'spreadbore'
Old Apr 12, 2009 | 02:42 PM
F-250 restorer's Avatar
F-250 restorer
Hey guys:
I wanted to run something by you which has been bothering me. I am about to send out an autolite 4100 to pony carbs to have them make one of their 'spreadbores'. They take the 1.12 venturi, (600 cfm) and install a shim or sleeve in the primaries, reducing the size to 1.00", and the secondaries become 1.19. All the sites say it works great, great milage, etc.
What bothers me is this: by narrowing the primaries, they are altering the velocity of the air flow, making it faster, especially going into the dp manifold I have, with the small primary runners. It seems that would also change the vacuum operated secondaries function, making them open sooner than normal, thereby cancelling out economy, the purpose of going with the 'spreadbore'. It also seems that the air flow, divided into the small runners of the offy dp intake, would be flowing so quickly, that it might lunge at take off. A bit of feed back here would be really welcome.
When I speak with Pony Carbs, they seem to tell me what I want to hear. Their set up is not cheap, and I'm trying to do the research before investing the $.
I need to decide whether to go with the spreadbore, or put on the smaller 1.o8 venturi (480 cfm) I have with the mustang numbers, designed for the 289.
I have both carbs, so I'm definetely staying with the autolite 4100. Thanks.
Old Apr 12, 2009 | 03:57 PM
Harte3's Avatar
Harte3
Interesting question. I don't know the answer. But a lack of velocity is usually the problem causing a weak signal in the carb for the proper fuel flow.
Old Apr 12, 2009 | 05:05 PM
91Bronc300's Avatar
91Bronc300
Is the vacuum setpoint for the secondaries not adjustable on those carbs? Shimming down the primaries would cause the vacuum signal to increase for a given airflow amount, causing your secondaries to open up at a smaller airflow than stock, but that would only be an issue if the secondary opening point is not adjustable. But being that those carbs have annular boosters why do you need to shim down the primaries? You should still have plenty of vacuum signal to get a very nice air/fuel mixture. That's why those carbs are so sought after in the first place. I don't have any input about your question about lunging because I couldn't even guess there, but I think you would be better served to use the carb as it is. Especially given the expense of chaning those venturi diameters
Old Apr 12, 2009 | 07:18 PM
Harte3's Avatar
Harte3
Tuning an Autolite 4100 Carburetor - Google Search
There are some articles on the 4100. I read one of them and it seemed like everything but secondary adjustment was covered. I'm just guessing but it might have an Qjet type, air flap system and should be adjustable.
Old Apr 14, 2009 | 01:47 AM
F-250 restorer
pony carbs 'spreadbore'
The reason to change the venturi is that the 4100 with the 1.12 venturi is a 600cfm carb, and too big for that engine.
EXPENSE: The shims to narrow the venturi are only $40. But what concerns me is that my engine has over size 1.94 intake valves, and is going to be pumping more air than stock, thereby sucking MORE mix through the carb. Thats much greater velocity for a 1.00" venturi, and thereby more vacuum.
I think I'll just stay with the stock 1.08 venturi (480cfm), and set the float level for a 302 sb, and see where that gets me.
Thanks,
Old Apr 14, 2009 | 01:52 AM
F-250 restorer
$$ Pony Carbs price!!
Whoa! Pony Carbs wants $400 bucks to rebuild my carb, plus postage both ways...and that's if I supply the core!
Old Apr 14, 2009 | 10:19 PM
Harte3's Avatar
Harte3
Pony is spendy. But you have the most desireable one there is...a 1.08...rebuild it yourself, tune and use that little beggar!
Old Apr 15, 2009 | 10:41 AM
Beechkid's Avatar
Beechkid
Culver Carburator is located in Lawndale ca.....probably looking at 50% for everything you want..call em to chat they have been in business since the 50's
F-250 restorer
39
Dec 5, 2012 10:44 AM
F-250 restorer
Apr 13, 2009 02:59 PM
bigwheelin
Sep 26, 2003 12:01 AM
