Engine is out again
Old Apr 12, 2009 | 01:04 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Engine is out again
Yeah Still cannot figure out what it is...
The other day me and my buddy went out to a long straight deserted road, got some videos, and for the first time i really ran the truck "hard" About three minutes later after it stalled. Changed out the CPS, still not starting, and noticed the oil pressure gauge not coming up. Got the truck home, checked the HPO reservoir and was 2" low, removed the reservoir, checked torque on the HPOP gear bolt, suspected it to be loose, not spinning the pump with the gear, however not the case. assembled it and began to crank it to see if it would start, went a half revolution and bogged down the starter, ground and kicked out, the motor just "locked up" for some odd reason. to make a long story short, the motor came out (again) today, which is just an afternoon affair anymore for me and a few buddies, removed the damper and oil pump however before the removal, and that wasnt the issue. Pulled the oil pan off, and there was the tube part of the oil cooling jet in the oil pickup, traced that back to cylinder 5 who's jet broke off, however it HAD to be recent, the motor ain't got that many miles on it....I removed all the glow plugs and such, no hydraulic lock, and its still a very abrupt and firm metal-metal contact when the engine is barred over by ratchet. I am going to pull the front cover tomorrow and see if the cam retaining plate bolts are still in, that could be just about the only thing left to check at this point..
Damn i am getting tired of this truck..
Old Apr 12, 2009 | 01:17 AM
Stewart_H's Avatar
Stewart_H
Sorry brother, I feel your pain.
Your PSD and my Lightning are kindred spirits.
Stewart
Old Apr 12, 2009 | 04:22 AM
Kwikkordead's Avatar
Kwikkordead
UGH
What a PITA!
Old Apr 12, 2009 | 06:31 AM
megawatt00's Avatar
megawatt00
I'm dumbfounded Kris....I hope that it is something simple and you get it running and this is all behind you.
Old Apr 12, 2009 | 07:26 AM
beanhead6D5's Avatar
beanhead6D5
Man Kris,that just sux.I hope its not to much damage.
Maybe you can win some money in a PSD eng pulling contest to off set some cost.
Old Apr 12, 2009 | 07:33 AM
F350-6's Avatar
F350-6
Sorry to hear this. Let us know what you find.
Old Apr 12, 2009 | 09:21 AM
Adam0331's Avatar
Adam0331
Hopefully you figure it out soon, once that thing runs right it is gonna rip.
Old Apr 12, 2009 | 05:03 PM
PowerstrokeJunkie
Well, i found out the problem, it's going to be a little more expensive than i thought.
I was working on the engine and something caught my eye that #4 exhaust valve was higher than the rest, hmm, so i pulled the head, and sure enough the valve seat was sitting there on top of the piston. The inital crunch where it stalled the starter had to come from the large part of it imprinting itself into the piston, my nice new custom 15:1 pistons, i hope i can get just one to replace it, ***** me if i gotta buy a whole new set and rebalance everything. Do you think it could have hurt the rod, when i did this CRANKING and not running? I am going to examine the valve and head a little more, i have inconel valves and don't know where they came from or how to get more, so i hope it's alright.
I guess it happened because of the extreme heat, really the first time that i got into it, not even in the highest setting, and this valve seat decides it can't hold the heat. I dont know what to do here, im getting tired of this extremely expensive hobby im paying on and cant even use and have fun, im considering fixing it, selling the go fast stuff and just getting a forged rod shortblock, and some hybrids?
click on the pic
Old Apr 12, 2009 | 05:34 PM
ernesteugene's Avatar
ernesteugene
The hottest cylinders are #8 followed by #6 and in any case steal valve seats tend to fall out of aluminum heads whereas with cast iron heads the steal insert has a larger coefficient of expansion than the cast iron does so the seats should hold tighter at higher temperatures. If the exhaust valve is burned and was sticking to its seat that might've pulled enough on the seat loosen it up or the recess for the seat might've been machined a tad to large to begin with.
There're a number of techniques that I'm aware of that at least work in gassers for repairing a valve seat including threading it in, cold shrinking a pressing it in, using high temp Locktite, and recessing the seat a tad below the cast iron surface and then after final assembly using a sharp punch to carefully work some of the cast material over the top of the seat and polish with emory cloth.
Old Apr 12, 2009 | 06:15 PM
yamaguy's Avatar
yamaguy
Yea but kris I thought you wanted the challange of running a 7.3 and not a cummins LOL. I hope you can get back on the road soon and enjoy the money you've spent.
Old Apr 12, 2009 | 08:43 PM
Izzy351's Avatar
Izzy351
Damn -- that sucks, Kris. I'm sure you'll get it figured out!! Stick with it...
Old Apr 12, 2009 | 09:44 PM
jdecker88's Avatar
jdecker88
Dang man it has just been one problem after another for you man I really hope you get this sucker lined out after this little spurt and maybe some more break in time .
Old Apr 12, 2009 | 10:07 PM
Adam0331's Avatar
Adam0331
Damn, that sucks man.
Old Apr 12, 2009 | 11:08 PM
87 F-150 I6's Avatar
87 F-150 I6
Dam, that is suck news. I would look at it this way, once you get it up and running, its going to be a dream! Hope you get it all back together and working with minimal money.
Old Apr 13, 2009 | 07:26 AM
03_PSD's Avatar
03_PSD
What a bummer Kris, hope you get her back up and running.
