Climate control problem
Old Apr 11, 2009 | 08:08 PM
Roosterhuntin's Avatar
Roosterhuntin
2006 with 45,000 miles on it. The direction of the air doesn't seem to be working when I move from Vent, Defrost and floor. The fan blower is working as you can hear the fan increase in power as you turn the dial. The heater and air work as you can feel the air change. When you move the dial to the floor, air still comes out the vents and defrost. When you move the air to vents, it still comes out the floor and defrost. Same goes for defrost (comes out the vents and floor). Any idea's what is wrong with it?
Thanks Guys!
Old Jul 13, 2009 | 08:56 AM
302svt's Avatar
302svt
I am having the same problem, I replaced the mode door actuator and that didn't help either. I am going to check the ac/heater control next.
Old Jul 13, 2009 | 11:51 AM
FTE Trigger's Avatar
FTE Trigger
May want to double check those vacuum lines too.
And you two...
Welcome to Ford-Truck Enthusiasts!
Old Jul 13, 2009 | 11:20 PM
302svt's Avatar
302svt
No vacumm lines in the newer trucks.
Old Jul 14, 2009 | 01:17 AM
LACityFD's Avatar
LACityFD
I have the same problem on a 2005 SCrew Lariat with electronic controls. I keep hitting the controls from floor to vent and it eventually changes. Some days it works as it should, other days it's annoying and won't budge.
If anyone figures out the fix, I'd love to hear it.
Old Jul 14, 2009 | 01:43 AM
FTE Trigger
Good catch... I forgot.....
Old Jul 14, 2009 | 08:22 AM
tooldad's Avatar
tooldad
I have the electronic controls. Had similar issues, but also problems changing from hot to cold and vice versa. Ford dealer replaced the blend acuator motor and eventually the entire blend box. Fixed problem.
