tranny troubles
Old Apr 11, 2009 | 07:48 PM
BrandonsF-150's Avatar
BrandonsF-150
tranny troubles
my tranny is whinning pretty good down the road, one two many rivers i guess, looked under and was wondering what the difference in the 2 and 4 wheel drive f150 5spd tranny, have heard that the 2 wheel drive has a longer tail shaft but as i got to looking my 4 wheel drive tranny has an adapter that goes from the tranny to the transfer case, its also where the cross memeber bolts to the tranny, could the adapter make up the difference for the tail shaft housing on a two wheel drive model, or do i indeed have to find a 4 wheel drive tranny? oh and its the mazda tranny they used in those trucks! the M5 i believe
Old Apr 13, 2009 | 10:33 AM
BrandonsF-150
know one in here can tell me if the tailshaft on a 2 wheel drive is longer than the tailshaft on the 4 wheel drive manual tranny, its the m5 tranny
Old Apr 13, 2009 | 10:40 AM
70torino429's Avatar
70torino429
i think the tailshafts are different and cant really be directly swapped but im not positive. id just find a 4wd trans if i was you so itd be a bolt up swap. someone on here should be able to give you more of a proffesional answer.
Old Apr 16, 2009 | 10:59 AM
BrandonsF-150
thanks for the help man
Old Apr 17, 2009 | 04:45 AM
BrandonsF-150
would anyone else have and knowledge on this? Could sure use it
Old Apr 17, 2009 | 10:29 AM
cjben's Avatar
cjben
there is a transmission forum on FTE also,might try your question there is you don't get an answer here.
Old Apr 17, 2009 | 10:42 AM
pc_2000's Avatar
pc_2000
I do know that from 2wd to 4wd or viceversa the output shaft has to be changed. This requires tearing down the entire transmission to swap it.
