Steering column bearings
Old Apr 11, 2009 | 05:14 PM
bashby's Avatar
bashby
The bearings in my dads 96 F250 tilt column have been bad a while, grinding and wheel flopping around. I'm looking for an exploded view of the column so I have a little better idea of what I'm getting into. I replaced them a couple years ago but the old ones were so destroyed I couldnt tell what went where and it still had some play when I was done.
Old Apr 11, 2009 | 05:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I don't know of anyone on FTE that would be able to assist you, because AFAIK, I'm the only one here with the correct Ford parts catalog...but it's on microfiche.
Your best bet is to visit your local Ford dealer...and look in his parts catalog...the partsguy can print out a copy of the specific column for you.
There are several FTE Ford Dealer parts department sponsors who could assist you, but since you have a local dealer...why not go there.
Old Apr 11, 2009 | 05:39 PM
bashby's Avatar
bashby
I actually did that last time but the picture wasnt clear enough to tell what went where. I've replaced them in one other truck with so-so results. It is a really strange bearing setup and the old ones were so destroyed I couldnt tell if I had the new ones in correctly. I know of 3 same era trucks with the same problem so it must be pretty common.
Old Apr 11, 2009 | 06:28 PM
subford's Avatar
subford
Is this what you want?
http://i54.photobucket.com/albums/g9...1996Column.jpg
Old Apr 11, 2009 | 07:51 PM
bashby's Avatar
bashby
Yeah, thats it. Thanks
Old Apr 12, 2009 | 06:57 AM
NumberDummy
The problem with that pic is...where are the Ford part numbers?
Excepting where the parts fit, you aren't going to know what the individual part numbers are.
Old Apr 12, 2009 | 08:09 AM
subford's Avatar
subford
He can get the base numbers for the part numbers here:
1996 Bronco/F-Series
Old Apr 13, 2009 | 03:48 AM
BigSix1's Avatar
BigSix1
Online Shop Manuals?
subford,
Hey...neat link. Is that from an online shop manual somewhere? I tried to go to the basic site, but it seemed like it was for diesel trucks only--my F-250 is gas-powered.
Also, I didn't actually find the shop manuals section, even for the diesels.
Thanks,
BigSix
Old Apr 13, 2009 | 07:10 AM
subford's Avatar
subford
Originally Posted by BigSix1
Is that from an on line shop manual somewhere?
No it is a few pages posted out of the 1996 Ford Truck Shop Manual.
It is a diesel site but a lot of the TSB and other stuff on that site is the same on the non-diesel trucks. Like the base part numbers for the column would be the same.
I do not think the shop manuals are on line anywhere anymore.
However you can buy the set of paper manuals from HELM Inc.
OR
Maybe you can buy a used set on ebay and they may sell the CD there too but the CD is not as complete as the manuals.
Old Apr 13, 2009 | 07:16 AM
NumberDummy
helminc.com
Helm has printed all of Ford's literature since the 1940's and has 1000's of original manuals available.
Old Apr 15, 2009 | 10:17 AM
Q in Sac's Avatar
Q in Sac
direction.....
I need to replace my steering bearings BAD! I need instructions on repairing and replacing. I going to Pick and Pull will an 86 to 96 steering column work. Need some info.
Old Apr 15, 2009 | 11:12 AM
bashby's Avatar
bashby
My 86 column is way different than my dads 96. I suggest adding a signature in your profile with info on your truck so you dont have to type it every time you have a question
Old Jun 2, 2009 | 12:15 AM
TexasGuy001's Avatar
TexasGuy001
subscribing
cadunkle
50
Nov 8, 2017 07:58 AM
VocaTexas
Nov 20, 2016 07:53 AM
workingdog
31
Oct 10, 2016 02:21 PM
T_Cooksey88
Mar 17, 2016 11:23 AM
