need some help
Old Apr 11, 2009 | 12:15 PM
forddriver17's Avatar
forddriver17
need some help
my tranfercase is makin some weird like grinding sounds when i accelerate but when im sitting still it doesnt make any sounds any ideas? and i just did a new clutch and flywheel in my truck and a dana 60 swap
Old Apr 11, 2009 | 12:19 PM
88f150302's Avatar
88f150302
is it a grinding or more of a whine are you sure it is the transfercase and not the tranny? i am no expert on this but it could just be gear lash somone else with more knowledge will chime in soon
Old Apr 11, 2009 | 01:01 PM
forddriver17
im pretty sure its the transfercase because i jacked the rear up and put it through the gears and went under and listened while it was spinnin the tires and its sounds like its from the transfercase
Old Apr 11, 2009 | 08:26 PM
ford trans tech's Avatar
ford trans tech
have you checked the fluid level in it
if it is empty stop immediatley and disassemble it because the pump will have seized and is now spinning in the case
further driving will destroy the transfer case
Old Apr 12, 2009 | 10:53 PM
forddriver17
yes i filled it with new fluid when i reinstalled it i talked to my uncle and he said might be the chain is worn out so i might just get a rebuild kit and rebuild it for 100ish any more ideas guys? i mean it does have atleast 300000 miles on it so i mean i guess i cant really complain
Old Apr 13, 2009 | 10:54 PM
PLC7.3's Avatar
PLC7.3
What type of fluid........ must be ATF
Once you get it open you will probably find $100 is not enough.... $500 can get you a good rebuilt on Ebay.
Old Apr 14, 2009 | 08:44 AM
forddriver17
well from my local parts store they said a rebuild for it is about 160 and yes i used ATF
