E4OD shift point trouble!
Old Feb 13, 2002 | 12:14 AM
ELKHUNTN's Avatar
ELKHUNTN
Recently, and for no appearant reason, the shift points have changed on my E4OD transmission. The truck: '97 HD F250, 4x4, 460 w/ 58K miles, and well maintained, and tranny has been serviced, fluid clean and full.
Suddenly the shift points have changed to 3500 - 4000 RPM for all gears, and shifts HARD! (yeah, finally the damn thing shifts hard, only when it is having troube...) It well not shift by itself until these RPM's are reached. The speedo and all other guages work fine, no blown fuses either. Also, I notice that when I let off the accelerator at any speed the truck coasts like it is in neutral.
I'm assuming something electrical, a switch, or???...
Does anybody have any ideas????
Old Feb 13, 2002 | 12:40 AM
RichF350V10's Avatar
RichF350V10
This may sound too simple, but have you checked the fluid level? This happend to me. I didn't realize that I had a leak. A small leak over time can lower the level enough to cause these symptoms.
Drive your truck about 10 miles to get everyting warmed up. Stop on a level surface. Before checking the level, shift the transmission between reverse, drive, and back to park. With the truck idling and parking brake set, check the transmission fluid level. It should be within the "hashed lines" on the dip stick.
Have you changed the fluid and filter lately? Cruddy fluid or a clogged passage could cause such problems.
I'm not too familiar with this exact transmission, however other contributors can be something like a problem with a throttle position sensor (transmission doesn't know how shallow or deep you're into the throttle). Check to see if any wires or lines are unplugged.
Find a reputable shop for diagnosis, not one that just wants to tear your trasmission out and charge you $2000. If in doubt, take it to several places. If they all say the same thing then that could be the problem.
Good luck.
Rich
2002 F350 4x4 V10 SCab
Old Feb 13, 2002 | 09:52 PM
ELKHUNTN's Avatar
ELKHUNTN
Rich,
Yes, tranny fluid is clean and full. No leaks. Had it service & fluid changed @ 30K. No other mechanical problems with this truck to date.
Anyone else w/ ideas?
Old Feb 24, 2002 | 12:32 PM
ELKHUNTN's Avatar
ELKHUNTN
Well, Got it fixed. Turned out to be a bad Throttle Position Sensor. Replaced it, no more trouble!
It is amazing to see what one bad switch/sensor can do to a computer controlled vehicle. The scanner found several errors: Bad EGR, TPS, Torque converter slipage, etc.
Replaced the switch and scanned again - no error codes.
Hopefully this info. will help someone else. Thanks for the replies.
Old Jan 3, 2003 | 07:12 PM
dddellinger's Avatar
dddellinger
Did your truck set any codes before you replaced the throttle position sensor? If not, how did you determine that was the problem?
Old Jan 3, 2003 | 10:26 PM
MW95F250's Avatar
MW95F250
Old Mar 29, 2009 | 11:26 AM
BILT4ORDTUF's Avatar
BILT4ORDTUF
What kind of scanner plug in does your's have? My son's 96 Model has the old style out by the hood hinge
Old Mar 29, 2009 | 07:39 PM
mrhorsepower67's Avatar
mrhorsepower67
Thanks a lot guys...that helped me too
Old Mar 31, 2009 | 09:19 AM
fkaster01's Avatar
fkaster01
that may help me also... my e4od trans slips into neutral above fifty mph, leading me to believe that its an od problem. tried pulling codes myself and the best i got so far is a 332, which is egr and probably not related, and a 452 which is the vehicle speed sensor/psom. I need to try to pull codes again and see if I can get a better reading (I have trouble counting the flashes properly i guess)
OldBlack4x4
Jan 9, 2015 04:43 PM
screaminford
Jan 24, 2011 09:29 AM
92 Red F150
Jun 3, 2005 09:46 PM
99Offroad
1997 - 2003 F150
Aug 20, 2004 08:33 PM
buckskin
1997 - 2003 F150
Dec 31, 2003 05:20 PM
