351 wont start
Old Apr 12, 2009 | 04:21 PM
xavier89's Avatar
xavier89
351 wont start
im new to the forum been reading on here for a while and never really made a profile untill today
i have a 93 f150 with a 5.8 4x4 pretty much stock
I got the truck about 2 weeks ago and never used the rear fuel tank so yesturday i came home and parked the truck and hit the switch and truck turned off my guess it had no gas so i hit the switch again t the front tank and now the truck wont start at all it cranks but no start i read the manual and it said something about a fuel pump switch found it and pushed the switch but nothing happend
Old Apr 12, 2009 | 04:33 PM
Ron W.'s Avatar
Ron W.
Start with the basics, what is the engine not getting, air, fuel or spark?
Old Apr 12, 2009 | 04:36 PM
xavier89's Avatar
xavier89
my guess its fuel but im not really too mechanical so i wouldn't even know how to check
Old Apr 12, 2009 | 05:21 PM
jr32560's Avatar
jr32560
can ya hear the fuel pumps running?-pull the coil wire and hold about an inch away from the coil and crank it look for spark-if ya got spark it might be fuel related
Old Apr 12, 2009 | 05:28 PM
Ron W.'s Avatar
Ron W.
Well then think of all the fun you're going to have learning, and buying tools and busting knuckles and and and......
Remove the air filter and while your there inspect the crankcase breather filter it's under the air filter make sure it and or the tubing to the throttle body aren't plugged = air.
No fun at all but without the proper tool or a timing light the best? way to check for spark is to pull a spark plug wire off of a plug and shove a key on the wire. Holding the key in one hand and leaning against the fender with the other hand have a buddy turn the engine over, if you've got spark you'll know it all the way up to the elbow.
For fuel the fuel rail has a schrader valve just like your tires Turn the key to the on (not crank) position and you should hear the pump prime the fuel system, then use a rag to catch any fuel and push in on the valve just like you were letting air out of a tire, only this time it should be gasoline coming out. Apressure reading would also be good to know.
By the way, when's the last time it was tuned? or any filters changed?
redbug
Dec 19, 2016 08:00 PM
jimbo beam
Dec 29, 2014 09:33 AM
DoofusOfTheDay
Nov 19, 2012 08:13 AM
biggyman50
Oct 12, 2010 09:44 PM
jamesmonty
Jun 26, 2003 08:50 AM
