Peculiar Noise
Old Apr 10, 2009 | 07:19 AM
Jeff Dodson's Avatar
Jeff Dodson
Peculiar Noise
My wife has a 05 EXPY with a 5.4. It has knocking noise, well dont know if its actually a knocking noise but kind a rattle type or tinging type knock, that would come from the exhaust. It sounds like its coming from the CATALYTIC CONVERTER on the passenger side.
If I open the hood to listen I cant find the noise. If I crawl under it, it seams like its farther up. Its more like an exhaust type tinging noise rather than a knock. I pretty sure its nothing inside the motor, but as I said it sounds like its up in the exahust from the CAT. Oh and BTW, it only makes this noise at idle, if you step on the gas the least little bit, it goes away.
Is it common for the CATs to go out quickly in these 05, it has about 80k on it.
Old Apr 10, 2009 | 02:31 PM
97EBexpedition's Avatar
97EBexpedition
My 97 EXPY 5.4L is doing the same thing. It started this winter. I changed the synthetic oil and added Lucas synthetic additive. The noise seemed to diminish, then it readmerged. I'm hoping to find some answers as well.
Old Apr 11, 2009 | 11:20 AM
alloro's Avatar
alloro
There is a TSB for the 97-98 models relating to CC noises:
https://www.ford-trucks.com/tsb/full...hp?tsb=04-20-6
As for a 2005, there is a different TSB:
https://www.ford-trucks.com/tsb/full...php?tsb=06-4-7
Amish65F100
Apr 5, 2017 08:37 AM
mjmck
Jan 22, 2016 10:27 AM
Last_Level_II
1983 - 2012 Ranger & B-Series
Sep 29, 2015 05:35 PM
F350Man79
Jul 28, 2014 07:59 PM
Brooce_AZ
Modular V10 (6.8l)
16
Dec 16, 2013 10:45 PM
