460 no spark
Old Apr 10, 2009 | 12:26 AM
aprice's Avatar
aprice
460 no spark
I have a 95 F-350 with a 460 and no spark.
Coils has been switched so that's good
Replaced the magnetic pickup in the dist
Power to the coil, distributor, and ignition module
Even pulled the spout connector
Ignition Module has been switched but from a 300/6 (should work????)
Also installed a new computer
I have fuel pressure. It seems, I have over looked something but what? Any one have an idea whats wrong, or what has been over looked?
The truck was in an accident, all the damage was to the leftside. No pinched wires, checked the grounds, no broken wires the enusha(sp?) switch was never triggered
Thanks in adance
Old Apr 10, 2009 | 06:43 PM
C-Leigh Racing's Avatar
C-Leigh Racing
Hummmmmm, seems like I remember hearing of a switch that will disconnect during a wreck.
I know there youst to be a fuel shut off on pickups after a wreck to stop fuel flow, may be ignition within the same switch, dont know. Would make since though.
Best I can remember, that fuel shut off switch is behind the right side kick panel under the dash.
Neil
