Sponsored by: Real Truck
OASIS - Multiple steering gear replacements?
Old Apr 9, 2009 | 07:50 PM
crackhead1's Avatar
crackhead1
We are about to close the deal on a 03 V-10 CC FX4 with 52K, 4" procomp lift and 35's.. The lift and tires are only 5K old, so I dont think that was the issue..I got the OASIS back and the steering gear box has been replaced 3 times.. The owner called me today and said that the steering went crazy on it yesterday and he took it in to the dealer.. They replaced the box and it didnt fix it, so they put a new pump on it and it took care of the issue.. What in the world would cause a truck with 52K to need to have had the steering box replaced 4 times?? Ill summarize the OASIS below.. I mean what gives? This truck is immaculate.. The steering on these things is stone cold simple.. What in the world would cause this??
June 03
Excessive free play, truck wanders, pulls right
Replaced steering gear and set toe
Nov 03
Customer reports excessive oversteer, feels like its darting when turning
Road test, stering vauge in center and heavy on turns, check steering gear preload peak 5 7 lbs center peak. Torque 1.4lbs. Replace steering gear check and set toe in. Road Test OK
June 04
Engine oil leak at right front of engine has oil on front end suspension andon ground
Inspect steering gear leaking. Replaced gear. C€heck and correct. Set toe. Road Test.
Jan 09
Other steering handling and ridet roubles. Power steering gearbox ports stripped and mounting bolt holes stripped.
Gear box R and R NP line treads in gear box messed up
Old Apr 10, 2009 | 11:32 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like they should have replaced the power steering pump all along, and all they did was kept replacing just the box.
Old Apr 10, 2009 | 11:51 AM
senix's Avatar
senix
I also suspect the lift is putting some extra strain on the whole system.
Old Apr 10, 2009 | 12:27 PM
crackhead1's Avatar
crackhead1
All these issues were before the lift was even put on... Hopefully the pump took care of everything..
