Chip install problem
Old Apr 9, 2009 | 04:51 PM
tjbeggs's Avatar
tjbeggs
I attempted to install a DP F5 single program chip on a 02 Excursion Limited today. Cleaned the contact just like always put it all back together no start and the theft light flashes rapidly. Pulled the chip and started fine. Chip back in and no start, rapidly flashing theft light. WTS, and CEL light all on.
Put the scanner on it and came out with a U1262 code.
Anybody run into this before? I am certain the contacts are clean so I am wondering if the theft light is an indication of some procedure I need to run through to kick start the anti theft. Not good sending a customer home without his chip......
Old Apr 9, 2009 | 05:05 PM
superduty4x4's Avatar
superduty4x4
Wish I could help ya TJ... haven't heard of anything like that before.
Old Apr 9, 2009 | 05:06 PM
just another truck's Avatar
just another truck
Tim, I dont know if this is possible, but just read someone running into the samething, they had the plug upside down.. Good Luck
Old Apr 9, 2009 | 06:32 PM
tjbeggs's Avatar
tjbeggs
I just triple checked the instructions and I had it in the right way. Oh and before any one says to contact DP I will but they are gone until the 13th so I am hoping someone has run into this before.
Old Apr 9, 2009 | 06:52 PM
PaysonPSD's Avatar
PaysonPSD
Sounds like you may be in Position 0.
Old Apr 9, 2009 | 07:03 PM
just another truck
Tim, I know this has happened a couple of times to others.. I just dont know how to use the search function.. One other thing I recall though was a ground clip in the PCM housing.. I did not see one when I did mine.. but I am sure there was an issue like that earlier this last month..
Old Apr 9, 2009 | 07:38 PM
tjbeggs's Avatar
tjbeggs
Originally Posted by just another truck
Nothing personal Robin.. but please PM them next time......??????????????????????????????????
Ground clip.....I did notice that still sitting on my box after the EX left the shop....Definitely gonna have to take it back out when it comes back.
Keep the options coming if you have any! thanks so far!
Old Apr 9, 2009 | 07:42 PM
tjbeggs's Avatar
tjbeggs
Yeah its only a single position chip. No switch.
Old Apr 9, 2009 | 08:00 PM
tjbeggs's Avatar
tjbeggs
I found a thread that is quite similiar and COuntrycar gave a procedure to correct it so I will give it a try when I can get the customer to come back in.
https://www.ford-trucks.com/forums/6...chip-swap.html
Post in particular
countrycar
Try this: 1)Make sure the key is out of the ignition, to begin. 2)Now Insert the key into the ignition. 3)Turn the ignition key on.DONOT START THE VEHICLE. 4)Watch the theft light on the dash it will be blinking rapidly Aprox 3 blinks per second, indicating Theft. 5) After a period of 30-45 seconds the theft light will blink slowly and or go out. 6) Now turn the key to the OFF position and remove it from the ignition. DONOT TRY TO START THE VEHICLE. 7) Wait for 10 seconds with the key out of the ignition. 8) Insert the key into the ignition. 9)Turm the key on, BUT DONOT START THE VEHICLE. 10)Look at the Theft light on the dash. The theft light will be blinking slowly..1 blink per second (Normal-Mode). 11) Then start normally after wait to start light goes out. It's easy to skip one of these steps so double check yourself. If you mess up just start over, No big deal. This should do it for yah. Take care. Country (On edit). This is the Procedure if the truck won't run. I see your is running though. HHMMMM. Never heard of this happening and the truck actually running. Sorry for the long post. Country
__________________
Old Apr 9, 2009 | 08:24 PM
just another truck
I hope that works for you Tim.. I wish I could find the other two threads I was talking about... Also, Put that ground clip back in.. I dont remember exactly what the problem was.. Man I wish I was better with this new search function.. I hear it is the whip when you figure it out
Old Apr 9, 2009 | 08:29 PM
megawatt00's Avatar
megawatt00
That ground clip grounds the PCM.
Old Apr 9, 2009 | 08:43 PM
tjbeggs's Avatar
tjbeggs
I haven't figured out the search either. Worked good before the last forum update but now....
Seems like a pretty foolish way to d it! but oh well. We will pull it again and put it back in.
Old Apr 9, 2009 | 08:49 PM
megawatt00's Avatar
megawatt00
I agree. When I installed my DP I made sure that the clip was there.
WIth the search try choosing the feature to search for words in the thread title.
Old Apr 11, 2009 | 01:07 PM
tjbeggs's Avatar
tjbeggs
Ok reinstalled the ground clip and chip and tried the key relearn. No go. Not good and getting mad!
Any other suggestions?
Old Apr 11, 2009 | 01:21 PM
tjbeggs's Avatar
tjbeggs
Also just noticed that after the 30-45 seconds of fast flashing it stops but then makes one long flash and 6 short flashes. Code 16?
