external transmission filter
Old Apr 9, 2009 | 02:26 PM
smoky_diesel's Avatar
smoky_diesel
I am looking for a wix/napa filter and base to use in the trans cooling circuit. Its for the C4 in my bronco not my PSD, but should be the same.
anyone added one to their truck here? Part Numbers? assuming any hydraulic type filter should work. magnetic type isn't going to work for me.
looking for something similar to this;
Automatic Transmission Filter Kits
but would rather get one today at napa if possible.
thanks
Old Apr 9, 2009 | 06:11 PM
DieselCamper01's Avatar
DieselCamper01
Not sure but here is a bump for you!
Old Apr 9, 2009 | 06:15 PM
superduty4x4's Avatar
superduty4x4
Check out Springer Pop's web page, he has a tranny filter setup.
Old Apr 9, 2009 | 06:37 PM
SpringerPop's Avatar
SpringerPop
SpringerPop's Transmission Filter
I have used an in-line filter, for about the last two decades, with lots of success. I have not had a transmission failure in that time. Had some before, especially with a Dodge A-604 UltraDrive POS.
Pop
Old Apr 9, 2009 | 06:45 PM
F350-6's Avatar
F350-6
I've always been a fan of Magna-fine.
Old Apr 9, 2009 | 06:47 PM
DieselCamper01
Any recommendation on a source for those Chris?
Old Apr 9, 2009 | 06:53 PM
DieselCamper01
Pop, I like your setup also. Just bookmarked that page. Thanks!
Old Apr 9, 2009 | 06:54 PM
F350-6's Avatar
F350-6
If you've got 2 hours to argue with the guy behind the counter at NAPA that such a thing really does exist, you can get one from them.
You can order one online from Bill at RacerX (an FTE sponsor) for around $14
MAGNEFINE COOLER LINE FILTER Racer X Automotive
Old Apr 9, 2009 | 07:01 PM
orng1's Avatar
orng1
I like Springerpop's better but I have used those smaller filters at work when replacing warranty transmissions. They came with every rebuilt transmission from Honda.
Old Apr 9, 2009 | 07:04 PM
DieselCamper01
That is the first place I tried to get one. I got the deer in the headlights look. lol
Thanks Chris.
Old Aug 6, 2009 | 07:27 PM
allis327's Avatar
allis327
Just found one of these on my truck no idea how long its been there. How often should a person replace them?
Old Aug 6, 2009 | 07:45 PM
SpringerPop
Depends on how you use the trans.
At any rate, since you're unsure about how long it's been, I'd JUST DO IT! The filters are cheap.
Afterward. maybe once a year. More often if you tow heavy.
Remember to add the make-up oil to compensate for what was in the filter.
Consider using some rare-earth magnets in the replacement filter's flange.
http://springerpop.net/F350/images/filter_magnets.jpg
They'll help keep the one in your trans pan cleaner, and you can periodically clean them.
Pop
Old Aug 6, 2009 | 07:50 PM
allis327's Avatar
allis327
Thanks, kinda figured that but wanted to be sure.
chuffer
13
Jul 25, 2017 03:38 PM
Duanne
Apr 14, 2016 11:34 PM
bulletpruf
30
Dec 26, 2015 12:56 PM
kidoo
Mar 5, 2012 03:31 PM
mufflerbearing
29
Feb 18, 2010 10:08 PM
