BW 1356
Old Dec 10, 2002 | 09:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
BW 1356
Old Jan 5, 2003 | 08:32 AM
christop43's Avatar
christop43
BW 1356
Pros and cons?
Old Jan 6, 2003 | 02:14 AM
the law's Avatar
the law
BW 1356
If they used 'em for more than a decade in F-350's, they can't be all bad. The one in my F-250 with 165,000 miles on it has performed flawlessly.
The Law
1989 F-250 HD 4x4
460, C6, BW 13-56, Sterling 10.25" (4.10:1), Dana 44 HD (4.09:1), twin K&N's, no muffler, stock lo-flo cat, Bosch Platinum Plugs (0.060") MSD 6A and TFI Blaster Coil
Old Jan 6, 2003 | 11:50 PM
Ryan50hrl's Avatar
Ryan50hrl
BW 1356
Well the aluminum case is weaker than a cast iron case, and the low range isn't all that low. But as said, they were used in one tons behind diesels so they are a good strong case.
Ryan
Old Jan 7, 2003 | 12:44 AM
the law's Avatar
the law
BW 1356
The Low Range on the 13-56 is 2.69:1. It's about average nowadays for a chain driven case. The almost legendary iron-cased, gear-driven NP 205 has a low range of only 1.96:1 or something to that effect. Unless you're into hard core rock crawling or just lack torque bad, 2.69:1 is just fine.
The Law
1989 F-250 HD 4x4
Old Jan 7, 2003 | 02:45 AM
christop43's Avatar
christop43
BW 1356
Thanks for the replies. I was just wondering since I know as much about transfer cases as I do rocket science. Now that winter is here I am in 4wd a lot and was just wondering. One more question, I have manual hubs, but when I shift it out of 4wd to 2wd it takes a long time for it to go into 2wd. If I backup it will pop into 2wd, I have been told this is due to binding, but most other trucks I see go back into 2wd almost instantly. Is there a problem here or is this common. Is there a fix?
Old Jan 7, 2003 | 11:28 AM
rebocardo's Avatar
rebocardo
BW 1356
Shift to N, then try shifting to 2x4, then to D.
Old Jan 8, 2003 | 12:13 AM
Ryan50hrl's Avatar
Ryan50hrl
BW 1356
Yeah..my apoligies....i was incorrect when refering to a lousy low range. I must have been drunk when writing it... I had the 205 and 13-56 low ranges mixed up in my head. anyhow...13-56's rule.
Ryan
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
