C6 interchangeability
Old Jan 8, 2003 | 08:53 AM
perryphilip's Avatar
perryphilip
[updated:LAST EDITED ON 08-Jan-03 AT 10:33 AM (EST)]I have an 85 Bronco with a 351W, C6, and an NP208 transfer case. My tranny is about to die and i'm looking for a good core to rebuild. My question is can i use a tranny that was bolted to a different transfer case like the borg warner. i already know that the bellhousings are the same between the 4.9 I6, the 5.0, and the 5.8.
What parts do i need to do a low ratio gear swap from an E4OD?
Also, i've heard that you can make your tranny shift better by adding more friction disks and pressure plates? if so, how many should i add during my rebuild?
thanks....
1985 Blue and White Bronco XLT, 351HO 4bbl, C6, NP208 ,9" 3.55 limited slip, Warn Premium Hubs, Quad Front Shocks, Dual Flowmaster 50's, BFG 32x11.5 ATko's
Old Jan 8, 2003 | 10:17 AM
AggiePSD's Avatar
AggiePSD
