Sponsored by: Real Truck
tranny noise
Old Apr 8, 2009 | 11:40 PM
okieplumber's Avatar
okieplumber
tranny noise
Have 01 f250 4x4 tranny makes a whining noise when put in gear forward or reverse. But no noise in park or neutral. The noise sounds like a power steering pump that is low on fluid. Any ideas?
Old Apr 9, 2009 | 01:14 AM
ReAX's Avatar
ReAX
Have you checked the fluid level? There is a pump in the transmission, a low fluid level should cause a delay, but if the fluid is aerated (lots of bubbles) it could cause this pump to whine I guess.
Old Apr 9, 2009 | 09:51 PM
okieplumber
Fluid level is ok. Tranny shifts fine and doesn't slip, just makes noise. Transmission man says if it aint broke don't fix it, says to drive it till it quits. Don't know?
