Power Door Lock Installation Lessons!!!!!!!
Old Apr 8, 2009 | 09:50 PM
usherac21's Avatar
usherac21
Well, I just finished installing my replacement power door locks. I learned a couple of lessons I want to share to help someone else avoid frustration.
1. When you test the the mechanism after putting the lock back together, make sure you close the door and test its function BEFORE putting the door panel back on. If you don't you might do like me and have a non-working door with all the mechanicals closed up inside the door and the door closed. I had to remove the door panel from inside the vehicle. The source of the problem was the rod inside the green swivel clip was not positioned correctly.
2. When working on the front doors, remove the courtesy light completely to avoid melting the plastic moisture barrier on the door. Don't ask how I know that.
All in all it went well. I'm glad to have my power locks back, which have been non-functioning since I bought the truck in August. The total cost of the project was 110.00 for the five window motors.
Old Apr 8, 2009 | 09:54 PM
da X-man's Avatar
da X-man
Window motors.
Old Apr 8, 2009 | 09:56 PM
usherac21's Avatar
usherac21
Oops...lock actuators...thanks.
Old Apr 8, 2009 | 10:07 PM
da X-man's Avatar
da X-man
No problem. I fixed my actuators back in November and have been working fine since then except for my front passenger one. It's weird because all the others work without problems except for that one. Also, you're not the only one who melted the plastic thingy.
Old Apr 8, 2009 | 10:13 PM
ReAX's Avatar
ReAX
All very important lessons to remember. I work the door latches with a screw driver so I can keep it open, but I've been there with the bulb.
CUINAK
Sep 27, 2019 10:48 AM
LH16
2015 - 2020 F150
Jan 7, 2017 05:55 PM
TexanAmmo
May 18, 2016 06:51 PM
0500757Arf
19
Nov 1, 2015 07:19 AM
