leaf spring bolts plz help
Old Apr 8, 2009 | 09:08 PM
fordguy300's Avatar
fordguy300
so i need help on removing the bolts to swap spring on my f150 its the rear driver side, the one i am putting in has a shackle on it whats the best way to get those bolts out, same with the ones on the truck? soak and bfh or what/? thanks guys
Old Apr 8, 2009 | 09:49 PM
subford's Avatar
subford
Cutting torch is what I use.
Old Apr 8, 2009 | 10:12 PM
HrdDrv's Avatar
HrdDrv
If you still have pressure on the spring, you need to jack up the rear until you get slack. (Truck on floor jacks, rear lifted with another jack.)
Old Apr 9, 2009 | 07:27 AM
Lazy K's Avatar
Lazy K
Exactly. Set fire to the rubber, wait ten min. and push rubber and bolt out. You can then heat the metal tube on the bolt and slide it off.
Old Apr 9, 2009 | 09:18 AM
fordguy300's Avatar
fordguy300
so im guessing im going to have to buy the end pieces,rubber, what are they and where do i get them? thanks guys
Old Apr 9, 2009 | 09:27 AM
Lazy K's Avatar
Lazy K
Yes you will need new bushes. You should get them at any auto parts store. Just ask for the spring bushes. You can go to RockAuto on line and get them. You might want to consider poly bushes, they are easier to fit.
