oil pressure sending unit
Old Apr 8, 2009 | 04:33 PM
projectdagger's Avatar
projectdagger
i have a 79 f-250 with the 460 engine and automatic transmission. i think the sending unit for the oil pressure has gone bad. I bought a replacement today. I can not find it on the engine. May i ask where is the location of it?
thank you for your time.. I hope you can help
Old Apr 8, 2009 | 05:38 PM
Jermafenser's Avatar
Jermafenser
It's at the back of the engine.
Old Apr 9, 2009 | 11:01 AM
projectdagger
I found it buried in the back. My question, are they difficult to replace?
Old Apr 9, 2009 | 11:06 AM
Jermafenser
Don't complicate things.
Just unscrew it and replace it.
Old Apr 10, 2009 | 06:37 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Should have one wire conneted to it, clean the area around it. Unhook the wire, should be a factory press on style connector. Make sure your new one has a o-ring, thread in the new one. Connect wire, open beer and your done.
You know now it the time to slice in a t-fitting and put an aftermarket psi gauge in,IMO
Old Apr 11, 2009 | 08:36 AM
Tees77f150's Avatar
Tees77f150
EXCELLENT!, I see you have a good work ethic!!
Old Apr 11, 2009 | 08:38 AM
77&79F250's Avatar
77&79F250
I forgot to say "start truck do a leak/psi check", then open another beer to celebrate.
Old Apr 11, 2009 | 11:14 PM
Tees77f150's Avatar
Tees77f150
YUP!, I like the way you do your thinkin!
