cluster question!
Old Apr 8, 2009 | 03:06 PM
myeg6's Avatar
myeg6
cluster question!
can i fit an 06 cluster on my 03 f350? i have the stock dash board!
Old Apr 8, 2009 | 06:00 PM
dchamberlain's Avatar
dchamberlain
If the 06 cluster has all the same gauges and lights that the 03 cluster has, it ought to work.
However... there are a few different clusters. There is a diesel set and a gas set. They have different indicator lights. There is an automatic set (with transmission temp sensor) and a manual set (voltage gauge instead of tran temp), etc. There may be other differences as well. The cluster is a programmed module, so there may be programming differences between the modules as well.
Given all that though, if you have the same gauges and lights, then most likely it would work, I would think.
Old Apr 8, 2009 | 06:55 PM
04F-250mark's Avatar
04F-250mark
I've wandered the same thing. What about the boost guage will it work with some wireing?
Old Apr 8, 2009 | 07:10 PM
dchamberlain
After thinking about it a while I am beginning to wonder if it would even work at all. A lot of what is displayed on the cluster comes from any one of a number of data busses. My 2004 6.0L, for example, has 4 distinct data busses. I believe (I am not certain), that as model years progressed, newer data busses came into being and older data busses became obsolete and were replaced.
On my model year, the console is connected to two of the data busses, the SCP bus and the UBP bus. The 2003 may or may not have those same busses and the 2006 may or may not have those same busses. If I understand it correctly, the trend is towards the newer CAN (Controller Area Network) bus. By '06, everything may be on it and the others may not exist. I just don't know, or know where to find out, short of having an '03 and an '06 service manual.
As to the boost gauge, boost data is carried on one of the networks. It is calculated based on the MAP sensor and the BARO sensor inputs.
