Installing tach/question
Old Apr 7, 2009 | 11:40 PM
diesel_73's Avatar
diesel_73
Thumbs up Installing tach/question
Hello - I am installing a tach in my 96 hightop. Any ideas on where to put it?....I dont really want to put it right on the dash, i was thinking possibly screwing the bracket into the bar between the windshiels and the door.....any ideas on the whole job would be appreciated!
Thanks,
Mike
Old Apr 12, 2009 | 08:23 AM
pfogle's Avatar
pfogle
I used a sunpro 3 5/8 inch tach in my '92. I reworked the bracket to fit the pillar on the left side of the windshield. It worked pretty well.
Old Apr 15, 2009 | 01:30 AM
diesel_73's Avatar
diesel_73
pfogle - Thanks for the reply. Wpild that be the bar going from the dash up to the roof separating the windshield from the drivers door?
Thanks,
Mike
Old Apr 16, 2009 | 09:22 AM
pfogle's Avatar
pfogle
Yes it was I no longer own the van so I can't take a picture for you or I would.
Old Apr 19, 2009 | 07:36 PM
Veetener's Avatar
Veetener
Diesel, I have a '98 V-10 gas E350 15-pass. It has about 95K miles. I bought it used from a Ford dealer in 04. I have done nothing to the van since I bought it except to change the oil every 3K. I don't know what the dealer did to the van before I bought it, but it runs so smooth and quiet that sometimes I can't tell if the engine is running, like when I'm stopped at a red. I think to myself, did the engine shut off? So I'm thinking of installing a tach so I can check if that V-10 is purring. Since you've done one, is it an expensive endeavour, or did you do it yourself?
EL
Old Apr 25, 2009 | 01:08 AM
pfogle's Avatar
pfogle
On the V-10 you may not be able to install a tach. You would need to build or buy and interface board to go from the digital ignition to the analog tach. THe V10 doesn't have just one coil, it has 10 individual ones. There is a tach reference wire in the computer but I don't think it would work for an analog tach. You might be able to find an instrument cluster with a tach in it. That would be a plug and play type upgrade.
Looks like it's possible.
https://www.ford-trucks.com/forums/1...10-engine.html
Old Apr 25, 2009 | 11:13 AM
shorebird's Avatar
shorebird
I have mine mounted of the A-pillar;
There is a dedicated tach feed wire in the harness for the V-10. pfogle no need for any fabrication. This gauge will work on the V-10 straight out of the box; http://www.equus.com/product_info.ph...ategory_id=100
Old Apr 25, 2009 | 01:36 PM
pfogle's Avatar
pfogle
When I did mine it was a 4/6/8 tach and COULD be used on a V10 with an adapter. It was in the instructions. Then again that was over 5 years ago now. Where did you get the mounting pods? I looked all over when I did mine and couldn't find anything that would fit without major modification.
Old Apr 26, 2009 | 02:45 PM
rclarke's Avatar
rclarke
I did some research on V10 tachs when I got my 03 E350. There are some tachs that can be modified by the manufacturer for use with the V10. My solution was a Scangauge II which can give you much more than just a tach. It plugs into the OBD plugin for a simple hookup. The Scangauge itself is small enough to install most anywhere.
Old Apr 28, 2009 | 12:51 AM
Texas Mad Man's Avatar
Texas Mad Man
Another happy scanguage user here. I mounted mine right above the 12 volt acc plug in and it is easy to see and operate.
Greywolf
General Automotive Discussion
May 14, 2009 07:36 PM
Greywolf
All Things Towing
Apr 26, 2009 08:35 PM
Greywolf
All Things Towing
Jun 22, 2008 08:01 AM
Greywolf
13
Jan 4, 2006 10:07 PM
Greywolf
Dec 29, 2005 09:36 AM
