Sponsored by: Real Truck
Antifreeze
Old Apr 7, 2009 | 01:23 PM
LKWDF350's Avatar
LKWDF350
Antifreeze
I noticed a problem with low start crank about a month ago and thought I should look into the batteries. I found both nuts on negative terminals hand loose from the time the motor was replaced. Both battery status are green. This lead me to believe the batteries are not properly grounded and they are not getting charged properly. Problem solved!
So then I noticed the radiator overflow had low antifreeze. What is the best antifreeze out there or what is recommended by you guys?
Old Apr 7, 2009 | 01:31 PM
senix's Avatar
senix
What year and motor do you have?
Old Apr 7, 2009 | 01:36 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
How low does the coolant level show? The old minimum line is now the maximum line - Ford made this revision some time ago in response to the coolant puking issues many were having. I'm surprised they didn't put a sticker on your degas bottle to reflect the change.
Old Apr 7, 2009 | 01:51 PM
LKWDF350's Avatar
LKWDF350
Yeah its a 06 F350 Diesel 4x4 LB. The coolant is below the minimum line while it sits in my driveway parked backwards on a decline (like my avatar pic).
Old Apr 7, 2009 | 02:00 PM
SteveBricks
FTE Emeritus
I assume that's what you're seeing when it's cold? As long as it doesn't exceed the minimum mark when hot on level ground you are fine.
Motorcraft Gold is the correct coolant.
Old Apr 7, 2009 | 02:02 PM
LKWDF350's Avatar
LKWDF350
Yes I meant when the engine is cold. Thanks for the tip.
skytrash
Apr 14, 2014 08:25 PM
fordpride
30
Feb 12, 2012 10:01 PM
Krazymaan
21
Jul 13, 2011 07:03 PM
MarkMoore
Modular V10 (6.8l)
16
Jan 9, 2008 07:00 PM
photomac
Nov 21, 2007 02:15 PM
