This spring the ground was soft and moist so the blade worked great, like a mini road grader. If it gets too hard and lumpy it`ll skip over alot of it, there`s no real down pressure. You`d be better of with a pull behind farm type land lever, that`ll bite in more. Check with Flaman Sales.
Thats the best and only time to rake leaves isn't it??? At least when I lived in town, thats the only time the neighbor raked his leaves.. Funny how they ALWAYS ended up in my yard. Now I don't have that problem. Lots of jackpine and what little leaves fall from the poplars, one breeze and they all blow into the woods. Problem solved!
I don't have one of them there platinum cards that you have ha ha.
Actually I would like to buy a little dozer in the future, I was just thinking of something that may work in the meantime
Actually the best deal I`ve ever seen for on the cheap is a big piece of used I-Beam or heavy angle iron with weights added on top of it. It`s used in gravel pits, anything that`ll level off hard packed and dried up clay/gravel mix has got to work just any where! About 12-15 feet of this will make super quick work when towed behind your hoe or your PSD. Don`t try it with your little Case though!
A dozer is ok, alot more $$ and it tends to dig into much with muddy conditions or where the ground is a little softer than the hard pack.
Hey thats a great idea! Ill have to look into that a little more!
Ive been thinking about a dozer for my business, thought i would use it around home too.
More I think about it, the more I think Im going to get a skidsteer next though. Then I can do smaller corrals, smaller lots for snow clearing, that sorta thing.
The hoe is overkill for alot of work thats available in this area.
I will actually probably get one from a ritchie brothers auction. I wouldnt need a super nice, new one for what i would use it for. I would need a good one though!
