Need to make a "Power Box"
Old Apr 7, 2009 | 11:17 AM
jam92102's Avatar
jam92102
Hey all. I am wanting to mount a power point inside the cab. Kind of an extension of the positive post on the battery. That way I wouldn't have to be going through the firewall all the time. What I would also like to do is, in the same box, make a power point that is ignition switched.
I figure I'd try to run maybe 1 four gauge cable from the battery, underneath the cab, and up through the floor near the back wall of the cab.
This would be in an enclosed box that I would make look real nice of course. I'm having trouble with how I can connect the cable to the box securly, without it grounding out to the truck.
Also if I find a ignition switched wire how do I hook it up to where the "ignition on" power can be disributed, without putting all the load on that wire? I'd appreciate any and all help you all can give me. Just let me know if you I haven't been clear enough.
Old Apr 7, 2009 | 01:24 PM
FTE Trigger's Avatar
FTE Trigger
I'm doing something similar in my truck. Except mine is mostly being housed in a electrical controls box (used in automated manufacturing) and using Pheonix Contact terminal blocks to distribute power from one wire. Pheonix also makes some nice terminal blocks with the ATC fuse holder integrated into it.
When I get home later I'll give you links and pictures (if I can find some). I'm also using S-O cable and MTW & Teflon wire for most of it.
Old Apr 7, 2009 | 01:48 PM
jam92102's Avatar
jam92102
Thanks Trigger. Any help you can give would be greatly appreciated.
Old Apr 7, 2009 | 10:23 PM
FTE Trigger
Here is a pic of the terminal blocks. The black ones are the blade/atc fuse holders. The blue ones are the double tier blocks (two or more functions) which in this picture has a barrier strip connecting a particular group together
1.) https://www.ford-trucks.com/user_gal...213316&width=0
2.)
Old Apr 7, 2009 | 10:33 PM
FTE Trigger
Use a Olflex strain relief / or liquid-tite strain relief. These are usually plastic with a rubber relieving ring that tightens around the cable- keeping it in place w/out grounding to the box or the truck. You may have to google it to find a "consumer" supplier.
Using a relay here would help (being routed to the terminal blocks). I am using a 30amp continous-heavy duty relay. For my uses I could have down-graded but it was the only cont./HD relay I had in my "toy box".
Old Apr 8, 2009 | 04:43 PM
FTE Trigger
After some time I'm thinking not everyone had a budget like mine to use in this manner.
The PC terminal blocks are about $2 ea. (w/out a large qty disc.)
The PC fuse holder blocks are about $10.50 ea. (" ")
So I've come up with some alternatives...
Instead of using the Phoenix Contact terminal blocks... you could use something like this:DOUBLE ROW TERMINAL BLOCKS TERMINAL BLOCK JUNCTION BLOCK* - Waytek Wire SCREW/DOUBLE ROW TERMINAL BLOCKS/TERMINAL BLOCK JUNCTION BLOCK/
Then in place of the barrier strips to group certain ones together you could use these:DOUBLE ROW TERMINAL BLOCKS TERMINAL BLOCK JUNCTION BLOCK* - Waytek Wire
Then to protect your circuits... here are inline fuse holders:BLADE FUSES CIRCUIT PROTECTION* - Waytek Wire
Here are the strain reliefs I mentioned earlier: Lapp Online Catalog Your local Controls/building electrical supply store should have something similar.
Old Apr 9, 2009 | 02:39 PM
wildcard30's Avatar
wildcard30
Your mounting plate shows L1 L2 L3....
You're not running 240 or 480 3 phase in your truck, are you?
Old Apr 9, 2009 | 05:16 PM
jam92102's Avatar
jam92102
Thanks for all the great ideas Trigger. As soon as it starts staying warm around here, I'll be cooking up my box.
Old Apr 9, 2009 | 10:25 PM
FTE Trigger
The back plane and the box... was used in a predom. 480 environment- then was made obsolete.
Let me know if you need more "stuff" or your more than welcome to PM or E-mail me for more detailed info.
