Sponsored by: Real Truck
superchip programmer
Old Apr 7, 2009 | 08:12 AM
rat49f6's Avatar
rat49f6
I have a chance to buy a superchips programmer from a friends older brother
It is off a 01 7.3and I have a early 99...will it work?
Anything I should look for as far as functions?
He said he paid 400 new and wants 200... very limited use ...he fell asleep and rolled the truck
Thx again
Jim
Old Apr 7, 2009 | 08:16 AM
Downriver Thunder's Avatar
Downriver Thunder
Alot of times they are VIN locked and you won't be able to use it on another truck. Unless you can get it flashed back.
Old Apr 7, 2009 | 08:35 AM
rat49f6's Avatar
rat49f6
ok... i have a very repuatable shop locally called level 10 they build trans and reflash stock ecus could they do it or just superchips can?
Old Apr 7, 2009 | 08:37 AM
Downriver Thunder
I'm not sure if it can even be done. I would call superchips to make sure before you spend the money.
Old Apr 7, 2009 | 09:05 AM
03_PSD's Avatar
03_PSD
You'll have to get Superchips to reflash it, or return the rolled truck back to stock, if thats possible.
Old Apr 7, 2009 | 11:48 AM
Lubbockguy1979's Avatar
Lubbockguy1979
Getting them unlocked I'd ver very expensive I'd check before buying it
Old Apr 7, 2009 | 11:59 AM
DieselBeast01's Avatar
DieselBeast01
You would have to return the rolled truck back to stock in order for it to work on your truck. If I were you I would just save up 300 more dollars and buy myself a DP tuner. It will blow that programmer out of the water.
Old Apr 7, 2009 | 12:01 PM
03_PSD's Avatar
03_PSD
or he could get at chip from Tony Wildman and blow the superchip outta the water. i should know i used to have a superchip now i got a TS chip tuned by Tony.
If you really want a good chip save your money and do it right the first time.
