Turbo Install This weekend
Old Apr 7, 2009 | 06:33 AM
bshep's Avatar
bshep
Well guys Im finally getting my turbo installed, just put new injectors and IP on. That alone made a small difference in power and a big differance in MPG, now its turbo time i I just bought a new RV.
I was looking through threads here and cant find what i'm looking for. I was wondering how you go bout bending the weld seams on the trans tunnel. I tried with a pry last night and they didnt really want to move. Any tips or tricks?
Thanks
Old Apr 7, 2009 | 08:22 AM
gnathv's Avatar
gnathv
Bending Seam
I cut three slots in mine with a roto zip with metal blade and then got on it with vice grips and bent it down. I have ATS 088 and the seam is bent pretty much behind the passenger side exhaust manifold.
Old Apr 7, 2009 | 10:43 AM
starmilt's Avatar
starmilt
You can also get ahold of Joe350 on here he has a hammer for every need.
The easiest way is cut it in a few places but a hammer and a large punch will work.
Old Apr 7, 2009 | 10:50 AM
bshep's Avatar
bshep
I never thought of cutting it. Thanks!
Old Apr 7, 2009 | 08:37 PM
harleyjohn45's Avatar
harleyjohn45
the ats manuel advises cutting about 18 inches of the insulation and rubber from the firewall. well i did and it made my truck hot inside. My down pipe is wrapped with header wrap, the cast iron up pipe has an aluminum shield on it (probably doesn't help the heat problem), and I also wrapped the crossover pipe in header wrap. Tomorrow I may try to get some insulation down between the pipes and the firewall, the problem being, its very close there.
Old Apr 7, 2009 | 09:15 PM
dyoung14's Avatar
dyoung14
thats going to be the hardest parts on my psd turbo the down pipe is going to have to hug the fire wall,
Old Apr 8, 2009 | 05:54 AM
bshep's Avatar
bshep
I got looking last night and it is going to be tight. I didnt really plan on wrapping the pipes but I think i'll do it now with hearing that. I wouldnt mind the extra heat in the cold winters here tho! haha. I'm hoping to complete this in 2 days if the wife/weather cooperate.
Old Apr 8, 2009 | 11:29 AM
starmilt's Avatar
starmilt
Yea is that New Brunswick you live in. I just noticed you guys are guing to have to type eh after every sentence so know where your from. LOL.
Old Apr 8, 2009 | 12:02 PM
bshep's Avatar
bshep
Yeah I'm in New Brunswick....eh hahaha
Old Apr 8, 2009 | 12:08 PM
starmilt's Avatar
starmilt
Now I know lol. I always wandered why canadians never typed eh. It kinda looks funny on paper. You used to be able to click on the user name and see where a member was from but something has been changed.
Old Apr 8, 2009 | 12:31 PM
bshep's Avatar
bshep
I'm not much for saying eh...well not as much as others. I'm from farther east and we say b'ye alot. that also looks funny on paper.
Old Apr 8, 2009 | 09:21 PM
harleyjohn45
Wrap everything you can with header wrap before you bolt it together. I managed to get the installer to wrap the down pipe and I had to do the crossover afterwards. I could not get header wrap on the cast iron up pipe, I wish I had insisted during the install. A lot of heat is generated in that pile of pipes.
Hose clamps holds the wrap on nicely. Be sure and wet the wrap before installation, so you can get a tight fit. It came out nice.
Old Apr 8, 2009 | 10:30 PM
dyoung14's Avatar
dyoung14
what do you wet the rap with?
Old Apr 8, 2009 | 10:57 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
You all use header wrap a lot, I don't like the stuff, I have seen many a race car burn to the ground because of it.
Soak it with oil from a blown motor and you have a serious oil torch.
Yea, I know the wrap itself does not burn, Yea Right!
The wrap will smolder and it will keep re-lighting even after time.. ie: an hour later after the wrecker has your blowed up and burnt car in your trailer, I know of one that burnt truck, trailer and all over an hour after they left the track.
Use a Ceramic coating inside and out, it's a bunch safer. And they say it holds more heat then header wrap. Also looks good.
-Enjoy
fh : )_~
Old Apr 8, 2009 | 11:00 PM
Festus Hagen
Methanoholic
Gasoline ...
NOT!!! Just kidding, Please don't do that!
Soak it in water!
-Enjoy
fh : )_~
